Date/Time: Tue, 21 Jan 2025 12:27:19 +0000
Does SC still support Windows XP?
View Count: 810
[2018-08-21 10:56:36] |
User123003 - Posts: 29 |
Does SC support Windows XP? I have a computer still using Windows XP, but I can't open SC on it, do I need to redownload and install SC again, please help. Thank you, Frank |
[2018-08-21 11:29:37] |
Yes Windows XP is fully supported. What exactly happens when you run the Sierra Chart program? Is there any error message.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-21 11:29:49
[2018-08-22 10:51:37] |
I got message on Service Connection Error: Error running C:/SierraChart\Rim\DTCBridge.exe. Windows error code 193:%1 is not a valid Win32 application. Thank you, |
[2018-08-22 10:52:12] |
Okay Rithmic does not support Windows XP. That is the problem.
[2018-08-22 13:19:55] |
Since Rithmic is not support Windows XP, then Which of following data feed and trade service do support Windows XP? CQG, CTS, TransAct, GainCapital, IQFeed, TT, TDAmeritrade, Interactive Broker, Google finance,Sierra Chart Real-Time and Historical Exchange Data Feed? I also would like to know how to set up to connect Google finance data feed. Thank you, |
[2018-08-22 18:13:32] |
With all of the others, Windows XP can be used. Here are the instructions for Google: https://www.sierrachart.com/index.php?page=doc/GoogleDataService.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-22 18:14:30
