Date/Time: Wed, 22 Jan 2025 00:33:47 +0000
Numbers Bars - v1791
View Count: 800
[2018-08-21 09:36:18] |
User907968 - Posts: 825 |
Hi support, A couple of small problems to report with the numbers bars study in v1791. 1) Percent compare thresholds (ln:91, 92 & 93) seem to reset to the default value whenever the chartbook is opened. 2) Extension lines (SG2 & SG3) will only show as a solid line, no matter what they are set to. Problem 1 doesn't seem to be present in v1790, but problem 2 definitely is. Thanks |
[2018-08-22 02:46:58] |
1) Percent compare thresholds (ln:91, 92 & 93) seem to reset to the default value whenever the chartbook is opened. 2) Extension lines (SG2 & SG3) will only show as a solid line, no matter what they are set to. We will look into this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-29 17:58:12
[2018-08-29 15:39:26] |
John - SC Support - Posts: 37369 |
With regards to #2, the Line Style has no effect when the Width of the line is 1. This is due to issues with the small size of dashes and dots and not really being able to see them when they are that small. The solution is to simply change the width to something larger than 1 and then change the Line Style to something other than Solid.
[2018-08-30 16:21:25] |
Ok, thanks for the information re #2, this is only an issue with recent releases, it has not always been the case.
[2018-08-30 17:31:17] |
