Date/Time: Wed, 22 Jan 2025 20:54:32 +0000
Feature Request: Multiple Selection in Alert Manager
View Count: 650
[2018-08-21 09:20:20] |
JanS - Posts: 46 |
It would be great if I could select multiple items in Symbol Alerts in the Alert Manager, using Shift-Click or Ctrl-Click or Ctrl-A. And the options in the right-click menu (like Delete, but Edit could be greyed out) should then apply to all selected.
[2018-10-26 17:47:19] |
This is planned. But Edit cannot apply to a multiple selection.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-26 17:47:50
