Date/Time: Tue, 22 Sep 2026 13:14:37 +0000
[Programming Help] - Basic c++ code
View Count: 1507
| [2018-08-21 05:41:26] |
| fraalbe - Posts: 12 |
Hi, is it possible in SC to print out same variables in a "console" ascii window? For example: // Section 2 - Do data processing here int z=99; cout << "The fourth result is " << z << '\n'; How can I open these console window to see the output? Date Time Of Last Edit: 2018-08-21 05:43:56
| [2018-08-21 16:22:07] |
| ForgivingComputers.com - Posts: 1238 |
No, but you can use the Windows Message Log: SCString MessageOut;
MessageOut.Format("The fourth result is %i", z); sc.AddMessageToLog(MessageOut, 0); |
