Date/Time: Tue, 21 Jan 2025 23:54:52 +0000
Expiry and Rollover
View Count: 813
[2018-08-20 16:10:42]
Ziklag - Posts: 73
How am I supposed to act/ respond to expiry/ rollover issues when your selection/ list of instrument from which I choose does not specify expiry dates? Kindly advise.
[2018-08-20 18:29:09]
You do see the list of symbols currently that you can choose from, correct?
[2018-08-21 04:37:15]
Ziklag - Posts: 73
I didn't say I do not see a list, what I said was specification does not include dates for an instrument that expires. USOIL for example; that is all there is. So on the day it is expiring I am completely helpless as just USOIL on the list gives me no rollover options. If I wanted to rollover it would be from what to what?
[2018-08-21 05:05:09]
This is a CFD and has no rollover.
[2018-08-21 08:24:09]
Ziklag - Posts: 73
It has - see attached; various USOIL instruments differing in expiry dates; why don't I have a choice, particularly important at or near expiry
attachmentFXCMCFDExpirations.pdf - Attached On 2018-08-21 08:19:05 UTC - Size: 314.5 KB - 675 views
[2018-08-25 11:44:27]
But there is nothing to change with the symbol itself.
