Date/Time: Tue, 21 Jan 2025 10:35:30 +0000
"Flatten and Cancel" - trading keyboard shortcut not responding.
View Count: 1831
[2018-08-18 06:02:30] |
User284663 - Posts: 44 |
I've tried using various keys, every other command works but no matter which key I assign the "Flatten and Cancel" command it doesn't work, the first time I encountered this problem I reinstalled Sierra Chart and it worked again however not long after reinstalling the issue is back, I can't be reinstalling each time.
[2018-08-19 04:49:10] |
Any updates? also is anyone else having this issue? Update: Log is saying "Reloading chart" each time I try to use the key. Date Time Of Last Edit: 2018-08-19 05:12:17
[2018-08-19 07:48:44] |
Attach the main configuration file so we can test this. This is in the Sierra Chart installation folder and the file name is Sierra3.CFG. Instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-19 07:49:01
[2018-08-19 08:31:43] |
Note that upon reinstall it seems to initially work, after time something occurs to halt the command.
Sierra3.cfg - Attached On 2018-08-19 08:30:04 UTC - Size: 399.6 KB - 397 views |
[2018-08-21 00:05:27] |
Using the configuration file you provided us, there is no keyboard chart assigned under Global Settings >> Customize Keyboard Shortcuts >> Trading Keyboard Shortcuts >> Flatten and Cancel. Also by default the Insert key will reload the chart if you happen to be trying to use that key. It is possible to remap it though. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-21 00:07:59
