Date/Time: Thu, 25 Apr 2024 16:44:35 +0000
How to download MQ Momentum indicator
View Count: 3241
[2018-08-17 18:45:41] |
User333450 - Posts: 4 |
I am a member of Basecamp trading and I have this MQ Momentum indicator that I purchased from them. I am new to Sierra Chart and do not know how to download this indicator onto my charts. Is there a link that shows how to do this? Thank you |
[2018-08-17 19:16:30] |
Can you have someone from Basecamp trading contact us at support@sierrachart.com about this. We want to explain to them what they need to do so you will get the files automatically installed.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-17 19:17:05
[2020-01-23 11:34:59] |
User924911 - Posts: 1 |
I have Downloaded and extracted MQ Momentum indicator and MQ BBF and MQ Momentum Trender Pro indicators from Base Camp Trading and they appear in the data folder of Sierra. however, when i go to the studies file only MQ Mom Trender Pro and MQ BBF indicators appear in the list of Custom Studies and I cannot get MQ Momentum to run at all. I get a message on the Chart saying Windows error code 193: %1 is not a valid Win32 application can anyone explain why the 2 work but not the 3rd indicator and why i get the error even though i can see the indicator in the data folder? Date Time Of Last Edit: 2020-01-23 11:35:48
[2020-01-23 23:52:11] |
Sierra_Chart Engineering - Posts: 14088 |
This sounds like a 32 bit versus 64 bit compatibility issue. Refer to: How to Use an Advanced Custom Study or a Study Collection: Custom Study Not Listed or Not Displaying on Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
