Date/Time: Tue, 21 Jan 2025 12:21:11 +0000
Sierra Charts Stocks Version
View Count: 992
[2018-08-17 16:51:55]
User653934 - Posts: 28
I'm away from home for several weeks and apparently made some error loading my Stock Version of SC on my USB. I don't mind starting over, but I don't have my login information. Can you send it to me. (I have my futures SC Version running fine.) Thanks, Sue
[2018-08-17 17:28:35]
Sierra Chart - Max - Posts: 5779
We have reset your Sierra Chart charting and trading software password. It has been sent in a separate e-mail to your e-mail address.
If you did not receive it, let us know. Your e-mail provider may have filtered the message and placed it in a junk mail folder.
For complete Login instructions and help with possible Login problems, refer to:
Sierra Chart - Software Login Instructions
If you continue to have a problem logging in, then let us know and provide us with the *exact* error message you see after pressing the Login button.
Sierra Chart Support
Date Time Of Last Edit: 2018-08-17 17:35:33
