Date/Time: Tue, 21 Jan 2025 10:40:30 +0000
Message Log Error
View Count: 1205
[2018-08-17 14:44:54]
Crtfyd - Posts: 281
With not knowing coding a given, I'm wondering if its possible, or why cant in the Message log the actual Study number that I have faulting be cited? It obviously knows where the fault is. Why such a general notice?
I'm getting repeated Message Log Errors "Chart #1 | Color Bar Based On Alert Condition. SubGraphData Array 0: Out of bounds array error at index 0 | 2018-08-17 10:31:02 *"
Ive had this before, but I have ALOT of studies (66, most of them the "Color Bar based on Alert") going, so going through each one to find which one is faulting would be arduous.
Future version?
If not, any idea of a more efficient way of checking?
[2018-08-17 17:28:10]
Yes we can add the study identifier number.
Date Time Of Last Edit: 2018-08-17 17:28:21
[2018-08-20 14:30:42]
Crtfyd - Posts: 281
Regarding this problem, I have been through all my "Color Based on.." studies, and can't find any errors. Obviously I missed something.
Is there a methodical way to doing this?
Am I looking for a comma missing, or a phrase that doesn't make sense?
Since its recent, I must have altered something.
I guess I don't know exactly what this error means, and I cant find anything in "Search>>support" on this.
Thx
[2018-08-20 15:01:32]
If you update to the latest prerelease, we did add the unique study identifier to the logging.
From your perspective it would really be hard to know what the issue is. And from our perspective we would not know unless we tested your Chartbook assuming we can reproduce the problem.
Date Time Of Last Edit: 2018-08-20 15:01:53
[2018-08-20 15:31:29]
Crtfyd - Posts: 281
I just updated to the latest Prerelease and I dont see any identifier in the log.
______________________________________________
Reading Internal Order ID file. | 2018-08-20 11:22:37
Reading Trade Orders file. | 2018-08-20 11:22:37
Reading Trade Positions and Account Balance file. | 2018-08-20 11:22:37
Listening on UDP port 22903. | 2018-08-20 11:22:37
Software version: 1791 64-bit | 2018-08-20 11:22:37
Usage end date: 2018-09-07 | 2018-08-20 11:22:37
Enabled for: Advanced Features. | 2018-08-20 11:22:37
Enabled for: Sierra Chart Historical Data Service. | 2018-08-20 11:22:37
Allow Support for Sierra Chart Data Feeds is enabled. | 2018-08-20 11:22:37
Current selected Data/Trading service: TransAct Trading | 2018-08-20 11:22:37
Chart Update Interval: 138 | 2018-08-20 11:22:37
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2018-08-20 11:22:37
2018-08-20 08:22:37 Local computer time | 2018-08-20 11:22:37
2018-08-20 15:22:37 Local computer time in UTC | 2018-08-20 11:22:37
2018-08-20 11:22:37 Local computer time in SC Time Zone | 2018-08-20 11:22:37
2018-08-20 15:22:36 Server time in UTC | 2018-08-20 11:22:37
Local computer UTC time and Server UTC time difference: 0 seconds. | 2018-08-20 11:22:37
Program path: C:\SierraChart\ | 2018-08-20 11:22:37
Data Files path: C:\SierraChart\Data\ | 2018-08-20 11:22:37
OS Version Number: 10.0 | 2018-08-20 11:22:37
Locale Setting: C | 2018-08-20 11:22:37
Checking for new symbol settings for service code transact.trading | 2018-08-20 11:22:37
HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2018-08-20 11:22:37
HTTPS connection to www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2018-08-20 11:22:37
Requesting symbol settings for service code transact.trading. Overwrite = on. | 2018-08-20 11:22:38
Received 5 login tokens. | 2018-08-20 11:22:38
Symbol settings received. | 2018-08-20 11:22:38
Processed 781 symbol settings. | 2018-08-20 11:22:38
HTTPS connection to www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2018-08-20 11:22:39
HTTPS connection to www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2018-08-20 11:22:39
Files to Open on Start up | Opening file: CURRENT U8.scid.cht | 2018-08-20 11:22:41
HTTPS connection to login.sierrachart.com:443 (1) | Socket gracefully closed by remote side. | 2018-08-20 11:22:42
HTTPS connection to login.sierrachart.com:443 (1) | Received socket Close event. | 2018-08-20 11:22:42
HTTPS connection to www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2018-08-20 11:22:43
HTTPS connection to www.sierrachart.com:443 (2) | Received socket Close event. | 2018-08-20 11:22:43
HTTPS connection to www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2018-08-20 11:22:43
HTTPS connection to www.sierrachart.com:443 (4) | Received socket Close event. | 2018-08-20 11:22:43
HTTPS connection to www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2018-08-20 11:22:45
HTTPS connection to www.sierrachart.com:443 (5) | Received socket Close event. | 2018-08-20 11:22:45
ESu8 [C] 1 Min #7 | Reloading chart. | 2018-08-20 11:23:12
ESu8 [C] 1 Min #7 | There are no continuous futures contract symbols. Loading data normally. | 2018-08-20 11:23:12
ESu8 [C] Daily #13 | Reloading chart. | 2018-08-20 11:23:13
ESu8 [C] 1 Trades #6 | Reloading chart. | 2018-08-20 11:23:43
ESu8 [C] 1 Trades #6 | There are no continuous futures contract symbols. Loading data normally. | 2018-08-20 11:23:43
ESu8 [C] 1 PriceChanges #8 | Reloading chart. | 2018-08-20 11:24:17
ESu8 [C] 1 Min #1 | Reloading chart. | 2018-08-20 11:24:52
HTTPS connection to login.sierrachart.com:443 (1) | Initiating close of socket by core. | 2018-08-20 11:24:52
HTTPS connection to login.sierrachart.com:443 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-20 11:24:52
HTTPS connection to login.sierrachart.com:443 (1) | Closed. | 2018-08-20 11:24:52
HTTPS connection to www.sierrachart.com:443 (2) | Initiating close of socket by core. | 2018-08-20 11:24:52
HTTPS connection to www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-20 11:24:52
HTTPS connection to www.sierrachart.com:443 (2) | Closed. | 2018-08-20 11:24:52
HTTPS connection to www.sierrachart.com:443 (4) | Initiating close of socket by core. | 2018-08-20 11:24:52
HTTPS connection to www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-20 11:24:52
HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2018-08-20 11:24:52
HTTPS connection to www.sierrachart.com:443 (5) | Initiating close of socket by core. | 2018-08-20 11:24:52
HTTPS connection to www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-20 11:24:52
HTTPS connection to www.sierrachart.com:443 (5) | Closed. | 2018-08-20 11:24:52
ESu8 [C-D] 1 Min #7 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESu8.scid | 2018-08-20 11:24:52
ESu8 [C-D] 1 Trades #6 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESu8.scid | 2018-08-20 11:24:52
Intraday data recording state for symbol ESu8 is set to download 'Pending'. | 2018-08-20 11:24:58
HD Request # 2 | Downloading Intraday chart data for ESu8 to the file ESu8.scid. Service: TransAct.Trading | 2018-08-20 11:24:58
HD Request # 2 | Download start date-time: 2018-08-20 11:15:15.000 | 2018-08-20 11:24:58
HD Request # 2 | Using server: ds4.sierracharts.com port 10149 | 2018-08-20 11:24:58
Socket (6) | Creating socket. | 2018-08-20 11:24:58
Socket (6) | Connecting to IP: 192.81.56.146. | 2018-08-20 11:24:58
HD Request # 2 | Setting DTC encoding to Binary VLS | 2018-08-20 11:24:58
HD Request # 2 | Sending historical data logon request message. | 2018-08-20 11:24:58
HD Request # 2 | Requesting Intraday data. Start date-time: 2018-08-20 11:15:15. Record interval: 0. Symbol: ESu8 | 2018-08-20 11:24:58
Socket (6) | Initiating close of socket by core. | 2018-08-20 11:24:58
Socket (6) | Shutdown started. Waiting for graceful close. | 2018-08-20 11:24:58
Socket (6) | Socket gracefully closed by remote side. | 2018-08-20 11:24:58
Socket (6) | Closed. | 2018-08-20 11:24:58
HD Request # 2 | Historical data for ESu8 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-08-20 11:24:59
Historical data download thread signaled to stop. | 2018-08-20 11:24:59
HD Request # 2 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESu8 | 2018-08-20 11:24:59
HD Request # 2 | Completion time: 2s | 2018-08-20 11:24:59
HD Request # 2 | Intraday data download complete for ESu8. Unique request ID: 1 | 2018-08-20 11:24:59
Removed historical data download ID 1 | 2018-08-20 11:24:59
HD Request # 3 | Downloading Historical Daily chart data for ESu8. Starting date: 2018-08-17. Service: TransAct.Trading | 2018-08-20 11:25:02
HD Request # 3 | Requesting historical Daily data for ESU18 starting at 2018-08-16 | 2018-08-20 11:25:02
HTTPS connection to historicaldata.sierrachart.com:443 (7) | Creating socket. Using TLS 1.2. | 2018-08-20 11:25:02
HTTPS connection to historicaldata.sierrachart.com:443 (7) | Connecting to IP: 88.99.0.216. | 2018-08-20 11:25:02
HD Request # 3 | Receiving historical Daily data for ESu8 starting at 2018-08-17 | 2018-08-20 11:25:05
HD Request # 3 | Writing historical Daily data to the file ESu8.dly | 2018-08-20 11:25:05
HD Request # 3 | Received 3 records from 2018-08-17 00:00:00 to 2018-08-20 00:00:00 (4.0 days) and wrote 2 records for ESu8 | 2018-08-20 11:25:05
HD Request # 3 | Completion time: 2s | 2018-08-20 11:25:05
HD Request # 3 | Daily data download complete for ESu8. Unique request ID: 2 | 2018-08-20 11:25:05
Removed historical data download ID 2 | 2018-08-20 11:25:05
TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-08-20 11:25:05
Created process C:\SierraChart\Transact\TransactToSierraBridge.exe. Parameters: /Port:13726. Current folder: C:\SierraChart\Transact | 2018-08-20 11:25:05 *
ESu8 [C] Daily #13 | Reloading chart. | 2018-08-20 11:25:05
TransAct Trading | Bridge process is running. | 2018-08-20 11:25:08
TransAct Trading | Connecting to the server 127.0.0.1. Port 13726 | 2018-08-20 11:25:08
DTC Client socket (9) | Creating socket. | 2018-08-20 11:25:08
DTC Client socket (9) | Connecting to IP: 127.0.0.1. | 2018-08-20 11:25:08
TransAct Trading | Connected to server. | 2018-08-20 11:25:08
TransAct Trading | Starting socket receive thread. | 2018-08-20 11:25:08
TransAct Trading | Setting DTC encoding to Binary | 2018-08-20 11:25:08
TransAct Trading | Sending logon request message. | 2018-08-20 11:25:08
TransAct Trading | Received logon response. | 2018-08-20 11:25:34
TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/. | 2018-08-20 11:25:34
TransAct Trading | Server protocol version: 4. Client protocol version: 8 | 2018-08-20 11:25:34
TransAct Trading | Successfully connected. Operation Successful. | 2018-08-20 11:25:34
TransAct Trading | Trading is supported. | 2018-08-20 11:25:34
TransAct Trading | Order cancel and replace is supported. | 2018-08-20 11:25:34
TransAct Trading | Connected to data and trading server. | 2018-08-20 11:25:34
TransAct Trading | Starting real-time market data updates for: ESu8. ID: 1 | 2018-08-20 11:25:34
TransAct Trading | Requesting security definition data for: ESu8. ID: 1 | 2018-08-20 11:25:34
Intraday data recording state for symbol ESu8 is set to download 'Pending'. | 2018-08-20 11:25:34
Delaying start of download for ESu8 | 2018-08-20 11:25:34
HD Request # 4 | Downloading Intraday chart data for ESu8 to the file ESu8.scid. Service: TransAct.Trading | 2018-08-20 11:25:39
HD Request # 4 | Download start date-time: 2018-08-20 11:15:15.000 | 2018-08-20 11:25:39
HD Request # 4 | Using server: ds3.sierracharts.com port 10150 | 2018-08-20 11:25:39
Socket (11) | Creating socket. | 2018-08-20 11:25:39
Socket (11) | Connecting to IP: 65.182.172.42. | 2018-08-20 11:25:39
HD Request # 4 | Setting DTC encoding to Binary VLS | 2018-08-20 11:25:39
HD Request # 4 | Sending historical data logon request message. | 2018-08-20 11:25:39
HD Request # 4 | Requesting Intraday data. Start date-time: 2018-08-20 11:15:15. Record interval: 0. Symbol: ESu8 | 2018-08-20 11:25:39
HD Request # 4 | Decompressing data. | 2018-08-20 11:25:39
HD Request # 4 | Receiving Intraday data for ESu8 starting at 2018-08-20 11:15:15 | 2018-08-20 11:25:40
HD Request # 4 | Timestamp of first Intraday data file record written: 2018-08-20 11:15:17 | 2018-08-20 11:25:40
Socket (11) | Initiating close of socket by core. | 2018-08-20 11:25:40
Socket (11) | Shutdown started. Waiting for graceful close. | 2018-08-20 11:25:40
Historical data download thread signaled to stop. | 2018-08-20 11:25:40
HD Request # 4 | Received 5752 records from 2018-08-20 11:15:15 to 2018-08-20 11:25:37 (10.4 minutes) and wrote 5751 records for ESu8 | 2018-08-20 11:25:40
Added 58 Time and Sales records to Intraday data file for ESu8 after download. | 2018-08-20 11:25:40
HD Request # 4 | Completion time: 1s | 2018-08-20 11:25:40
HD Request # 4 | Intraday data download complete for ESu8. Unique request ID: 3 | 2018-08-20 11:25:40
Removed historical data download ID 3 | 2018-08-20 11:25:40
Real-time Intraday chart data file updates started for ESu8 | 2018-08-20 11:25:40
Intraday chart data file opened for ESu8 | 2018-08-20 11:25:40
Socket (11) | Socket gracefully closed by remote side. | 2018-08-20 11:25:40
Socket (11) | Closed. | 2018-08-20 11:25:40
Chart #1 | Color Bar Based On Alert Condition ID: 0 SubGraphData Array0: Out of bounds array error at index 0 | 2018-08-20 11:25:40 *
Opened cached Intraday file: C:\SierraChart\Data\ESu8.scid | 2018-08-20 11:25:41
Chart #1 | Color Bar Based On Alert Condition ID: 0 SubGraphData Array0: Out of bounds array error at index 0 | 2018-08-20 11:26:02 *
Chart #1 | Color Bar Based On Alert Condition ID: 0 SubGraphData Array0: Out of bounds array error at index 0 | 2018-08-20 11:27:00 *
File >> Disconnect selected. | 2018-08-20 11:28:00
DTC Client socket (9) | Initiating close of socket by core. | 2018-08-20 11:28:00
DTC Client socket (9) | Shutdown started. Waiting for graceful close. | 2018-08-20 11:28:00
DTC Client socket (9) | Socket gracefully closed by remote side. | 2018-08-20 11:28:00
DTC Client socket (9) | Closed. | 2018-08-20 11:28:00
TransAct Trading | Disconnected. | 2018-08-20 11:28:00
HTTPS connection to historicaldata.sierrachart.com:443 (7) | Socket gracefully closed by remote side. | 2018-08-20 11:28:05
HTTPS connection to historicaldata.sierrachart.com:443 (7) | Received socket Close event. | 2018-08-20 11:28:05
HTTPS connection to historicaldata.sierrachart.com:443 (7) | Initiating close of socket by core. | 2018-08-20 11:28:05
HTTPS connection to historicaldata.sierrachart.com:443 (7) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-20 11:28:05
HTTPS connection to historicaldata.sierrachart.com:443 (7) | Closed. | 2018-08-20 11:28:05
[2018-08-20 22:25:12]
This is the identifier:
The problem though is that it always shows 0 and we will fix that.
