Date/Time: Tue, 21 Jan 2025 12:23:05 +0000
[Programming Help] - Search columns for multiple criteria
View Count: 671
[2018-08-17 14:04:03]
User345323 - Posts: 18
Hello, I'm trying to reproduce COUNTIFS excel function with spreadsheet.
I need to reproduce this attached exemple.
-------A--------B-------C
1---DATA1-----DATA2-----RESULT
2---10---------1----------2
3---5----------1----------3
4---7----------0----------0
5---5----------0----------2
6---3----------0----------0
7---4----------1----------1
8---10---------1----------1
9---5----------1----------2
10--6----------1----------1
11--5----------1----------1
I NEED TO SUM HOW MANY TIMES ON TWO COLUMNS I GET VALUE
OF CELL A2 COMBINED WITH NUMBER 1,
OR CEL A3 COMBINED WITH NUMBER 1
I CAN'T SEARCH THEM WITH IF AND THEN SUM THEM ON OTHERS COLUMNS BECAUSE
COLUMN A CAN HAVE FROM 1 TO 100 VALUE AND CAN'T USE SOO MANY COLUMNS
ANY SIMPLE WAY TO DO IT AS EXCEL DO IT WITH COUNTIFS?
With old spreadsheet I get correct result with:
=SUMPRODUCT((A2:A11 = A2) * (B2:B11 = 1))
but it's very CPU heavy for my computer.
Thanks for the help.
Regards
Date Time Of Last Edit: 2018-08-17 16:46:24
imageexample.jpg / V - Attached On 2018-08-17 13:58:24 UTC - Size: 128.37 KB - 264 views
[2018-08-17 15:03:03]
Any solution Sierra Chart support?
Tnx
[2018-08-18 10:24:06]
Up ... any help please?
Thank you
