Date/Time: Sun, 24 Nov 2024 11:04:22 +0000
Possible functionality for TPO chart
View Count: 1447
[2013-10-21 16:09:14]
ShayHagag - Posts: 2
I added a file from another system with 2 questions:
1.is it possible to add in the TPO chart the actual Midpoint of the chart (HalfBack)?
as today you only have the midpoint of the TPO count.
2. is it possible to add volume to the TPO chart like in the attached picture with mark High volume nodes?
Thanks,
Shay
imageTPO for Sierra.png / V - Attached On 2013-10-21 16:03:21 UTC - Size: 196.63 KB - 482 views
[2013-10-22 04:01:04]
1. No.
2. For this we recommend that you also add the Volume by Price study to the chart and that you perform the necessary splits on a TPO profile to get the particular subperiod you want displayed on its own . The volume profile will be displayed separately for it. Here is the documentation for this:
http://www.sierrachart.com/index.php?l=doc/doc_TPOVolProfileCharts.html#SplitMerges
[2013-10-22 07:21:37]
trademechanics - Posts: 29
Hi Shay
What you're trying to do with TPO charts (mimic Dalton's screen) it cannot be done in Sierra, yet.
What you can do is use the VbP study on a standard candle/bar chart and plot one for the entire session and another just for the last bar.
It will give you the view you want, just not with a TPO look.
Date Time Of Last Edit: 2013-10-22 07:24:22
imageWT.png / V - Attached On 2013-10-22 07:21:34 UTC - Size: 42.13 KB - 458 views
[2013-10-22 07:43:06]
Thanks,
I have the VBP in the TPO chart i will add another one with Bar chart.
