Date/Time: Tue, 21 Jan 2025 12:12:18 +0000
Chartbook and Charts
View Count: 1367
[2018-08-17 11:14:12] |
narcese - Posts: 58 |
When I create a new chartbook and the charts within the chartbook they will not remain saved when i close out of sierra. Solution?
[2018-08-17 13:56:00] |
ForgivingComputers.com - Posts: 988 |
Save the Chartbook. Do File>>Save or File>>Save As
[2018-08-17 17:15:15] |
Also, it sounds like the option to always ask to Save when exiting Sierra Chart is turned off. You may want to ensure that this option is checked (on) to ensure that you save your data when exiting: General Settings Window: Display Save All Option on Exit (Global Settings >> General Settings >> GUI >> Application GUI) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-17 18:19:35] |
Someone needs to get these charts working properly. We need someone to do a remote view.
[2018-08-17 18:52:22] |
So when you select File >> Save before closing the Chartbook and then you reopen the Chartbook with File >> Open Chartbook, you are not seeing the same layout?
