Date/Time: Tue, 21 Jan 2025 12:26:49 +0000
chart problems white box showing
View Count: 750
[2018-08-17 10:47:44] |
canyiah - Posts: 48 |
One of my charts is not showing anything expect a white box and part of the background color.
Untitled.jpg / V - Attached On 2018-08-17 10:46:47 UTC - Size: 509.88 KB - 284 views |
[2018-08-17 11:25:02] |
Would be easiest just to close that chart and open a new one rather than trying to figure out what the particular issue is. One quick thing you can do though is select Chart >> Reset Scales. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-17 11:25:24
