Date/Time: Tue, 21 Jan 2025 10:51:09 +0000
Is it okay to copy chart data files from main to second instance?
View Count: 1051
[2018-08-17 09:19:19] |
User814219 - Posts: 38 |
I know very well that when using multiple instances, each instance should have its own data folder. The question is, when creating a new instance, is it imperative that I let the new instance download historical/intraday data (that I already have on my main instance of Sierra) from my data service provider (i.e. CQG) all over again OR is it fine if I simply take the chart data files from the main Sierra instance and copy paste them into the second instance's data folder. Copy + pasting is so much faster than having to re-download all that intraday data over the internet through my data service provider all over again so I thought it would be worth asking. Date Time Of Last Edit: 2018-08-17 09:20:32
[2018-08-17 13:52:11] |
ForgivingComputers.com - Posts: 988 |
Copy/Paste is fine. You may end up copying more than if you downloaded, but you will get identical results.
[2018-08-17 17:30:52] |
is it fine if I simply take the chart data files from the main Sierra instance and copy paste them into the second instance's data folder. Documentation: Using DTC Server for Data and Trading in Another Sierra Chart Instance: Using DTC Server for Data and Trading in Another Sierra Chart Instance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-17 17:31:19
[2018-08-20 04:11:00] |
User post deleted. It was a duplicate.
