Date/Time: Sat, 06 Jul 2024 04:16:02 +0000
[User Discussion] - How to change Last Price Tag text color and Study Value Label Tags text color
View Count: 2239
[2013-10-21 15:11:57] |
User30668 - Posts: 108 |
Hello SC Support, The "Last Price" tag text color is showing with the same color as the chart background in all my charts. The same is happening with the Studies "Value Labels" tags. It looks like the tags text has no color (transparent). Please see the screenshot attached. Depending on the color of this tags and / or the charts background, sometimes it is not easy to clearly read the numbers. I have been trying to figure out how to change the color of the text of those tags (ie black) but I couldn't. Is it possible to do it? Thanks in advance. |
[2013-10-22 04:15:41] |
For the last price box, you change that with Global Settings >> Graphics Settings >>Last Trade Price Box. For the studies, the label will have the same color as to study subgraph color. This should be obvious. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-10-22 04:16:44] |
We see now that you referring to the text color and not the background color of the labels. The text color is not changeable. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
