Date/Time: Tue, 21 Jan 2025 12:19:38 +0000
Time scale text background colour
View Count: 1916
[2018-08-17 03:15:06]
User629461 - Posts: 184
Hi SC - I cant find how to change the background colour of the time scale text boxes at the bottom of the chart from black to white?
http://www.sierrachart.com/image.php?Image=1534475426216.png
[2018-08-17 15:14:45]
John - SC Support - Posts: 37327
You can change this by unchecking the following setting: Chart >> Chart Settings >> Advanced Settings >> Highlight Timescale Dates, Months, Years.
Although, contrary to what the setting states, if you are looking at a chart with a Daily or higher time frame, the Year will always be in the reverse colors (with the background box).
You will find the documentation for this setting here:
Chart Settings: Highlight Timescale Dates, Months and Years (Chart >> Chart Settings >> Scale menu)
