Date/Time: Tue, 21 Jan 2025 10:42:03 +0000
Large Volume Symbol - Bid, Ask, Price?
View Count: 665
[2018-08-16 14:10:35] |
User104854 - Posts: 457 |
Is there a way to extract the info when a large order hits as to if it was a buy or sell order and the price that it was executed at? I see that the symbol is accurate on the chart but I'd like to use this info in a spreadsheet. If not is there another study that does this?
[2018-08-16 17:17:57] |
Refer to: https://www.sierrachart.com/index.php?page=doc/helpdetails31.html#TimeAndSalesSpreadsheet Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
