Date/Time: Tue, 21 Jan 2025 10:48:19 +0000
Display buy/sell volume per bar
View Count: 1948
[2018-08-16 12:05:08] |
User215628 - Posts: 1 |
Is there a way to see buy/sell volume per bar? The volume study just shows total volume per bar but I'd like to split it. How can I do that? |
[2018-08-16 17:03:30] |
You can use the studies Bid Volume and Ask Volume or Bid Volume vs Ask Volume study or the Numbers Bars Calculated Values study. There are also a few others that have ways to show this data. Each of these has different ways of displaying the data, so you will need to review and see what works for how you want to see the data. The following are the links for the documentation for the various studies: Bid Volume Ask Volume Bid Volume vs Ask Volume Numbers Bars: Displaying Numeric Information Below Numbers Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
