Date/Time: Sun, 24 Nov 2024 11:00:09 +0000
Continuous alarm and window POP OUT to the occurrence of a condition
View Count: 1278
[2013-10-21 14:53:52] |
bercor - Posts: 30 |
Hello .. kindly one of you could tell me how to insert an alarm continue sounding until you take it off me. Simple example but for me to understand: I would like that if RSI super 80 sounds continuously. I am gone from the menu ANALYSYS STUDIES seloziono RSI SETTING and in the window ALERTS I put the condition. When the condition occurs makes me a single sound but often do not feel they are seen only tree sounds. It is possible to make out a window that POP OUT signals the alarm and continue sounding like the IB trading platform. And not just the line ALERT MANAGER "in the Windows menu? Thanks in advance to those who want gentilemnte tell me the solution ... |
[2013-10-22 03:22:57] |
It is possible to set the number of times an Alert Sound Number can play a sound file. This is explained here: http://www.sierrachart.com/index.php?l=doc/doc_GeneralSettings.html#AlertSoundSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
