Date/Time: Tue, 21 Jan 2025 10:44:26 +0000
Cant send orders to gain
View Count: 674
[2018-08-15 16:17:04] |
User798235 - Posts: 10 |
Hi! i cant seem to send orders to gain futures through sierra, works fine when putting orders in the gain plattform, Have worked before and i dont get any message in the message log. When i check orders and positions it only says "error" https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=21306 |
[2018-08-15 17:14:26] |
You need to follow the instructions here in regards to this: https://www.sierrachart.com/index.php?page=doc/GAINCapitalOECTrader.php#DisablingUseOfAccountAllocationForOrders (Disabling Use of Account Allocation for Orders) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-15 17:14:44
