Date/Time: Tue, 21 Jan 2025 10:48:05 +0000
Can't connect to Bitmex
View Count: 1274
[2018-08-15 16:06:41]
User384503 - Posts: 1
Every time I load up the software I need to generate a new API key for Bitmex and the restart the Sierra software. Now not even that is working and I can't connect to Bitmex at all. I am pretty sure I still have time left on my account until the end of the month?
Reading Internal Order ID file. | 2018-08-15 05:29:13
Reading Trade Orders file. | 2018-08-15 05:29:14
Reading Trade Positions file. | 2018-08-15 05:29:14
Listening on UDP port 22903. | 2018-08-15 05:29:14
Software version: 1713 32-bit | 2018-08-15 05:29:14
Usage end date: 2018-08-30 | 2018-08-15 05:29:14
Enabled for: Advanced Features. | 2018-08-15 05:29:14
Enabled for: Sierra Chart Historical Data Service. | 2018-08-15 05:29:14
Allow Support for Sierra Chart Data Feeds is enabled. | 2018-08-15 05:29:14
Current selected Data/Trading service: BitMEX Trading Direct | 2018-08-15 05:29:14
Chart Update Interval: 500 | 2018-08-15 05:29:14
Time Zone: +00:00:00 (UTC+00) | 2018-08-15 05:29:14
2018-08-15 15:29:13 Local computer time | 2018-08-15 05:29:14
2018-08-15 05:29:13 Local computer time in UTC | 2018-08-15 05:29:14
2018-08-15 05:29:13 Local computer time in SC Time Zone | 2018-08-15 05:29:14
2018-08-15 05:29:13 Server time in UTC | 2018-08-15 05:29:14
Local computer UTC time and Server UTC time difference: 0 seconds. | 2018-08-15 05:29:14
Program path: C:\SierraChart\ | 2018-08-15 05:29:14
Data Files path: C:\SierraChart\Data\ | 2018-08-15 05:29:14
OS Version Number: 6.1 | 2018-08-15 05:29:14
Locale Setting: C | 2018-08-15 05:29:14
Checking for new symbol settings for service code bitmex.dtc.trading | 2018-08-15 05:29:14
HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2018-08-15 05:29:14
HTTPS connection to www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2018-08-15 05:29:14
Symbol settings are up-to-date for bitmex.dtc.trading | 2018-08-15 05:29:14
Received 5 login tokens. | 2018-08-15 05:29:14
HTTPS connection to www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2018-08-15 05:29:16
HTTPS connection to www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2018-08-15 05:29:16
HTTPS connection to www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2018-08-15 05:29:19
HTTPS connection to www.sierrachart.com:443 (4) | Received socket Close event. | 2018-08-15 05:29:19
HTTPS connection to www.sierrachart.com:443 (4) | Initiating close of socket by core. | 2018-08-15 05:29:19
HTTPS connection to www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-15 05:29:19
HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2018-08-15 05:29:19
HTTPS connection to www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2018-08-15 05:29:19
HTTPS connection to www.sierrachart.com:443 (2) | Initiating close of socket by core. | 2018-08-15 05:29:19
HTTPS connection to www.sierrachart.com:443 (2) | Received socket Close event. | 2018-08-15 05:29:19
HTTPS connection to www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-15 05:29:19
HTTPS connection to www.sierrachart.com:443 (2) | Closed. | 2018-08-15 05:29:19
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-08-15 05:29:20
BitMEX WebSocket | Connecting to WebSocket server. | 2018-08-15 05:29:20
BitMEX WebSocket socket (6) | Creating socket. Using TLS 1.2. | 2018-08-15 05:29:20
BitMEX WebSocket socket (6) | Connecting to IP: 52.51.127.8. | 2018-08-15 05:29:20
BitMEX WebSocket | Opening WebSocket. | 2018-08-15 05:29:20
BitMEX WebSocket | Sending WebSocket handshake. | 2018-08-15 05:29:20
BitMEX WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-08-15 05:29:21
BitMEX WebSocket | Header line. Date: Wed, 15 Aug 2018 05:29:21 GMT | 2018-08-15 05:29:21
BitMEX WebSocket | Header line. Connection: upgrade | 2018-08-15 05:29:21
BitMEX WebSocket | Header line. Set-Cookie: AWSALB=iJWz+K0wCSVH7n85ufH86kNp1JQIWqrqx9iVLSV62mzx8MWeG1bCTndUGLdc0p+vr9SMRxBWrt7HAafuWaRaqzrT+XVjHzZ7aGhcyTUZ379pcPpjkLLT/kFmxuRm; Expires=Wed, 22 Aug 2018 05:29:21 GMT; Path=/ | 2018-08-15 05:29:21
BitMEX WebSocket | Header line. Upgrade: websocket | 2018-08-15 05:29:21
BitMEX WebSocket | Header line. Sec-WebSocket-Accept: Q6FKSvw/z2OimFzhU1w7/7em0TE= | 2018-08-15 05:29:21
BitMEX WebSocket | Header line. Sec-WebSocket-Version: 13 | 2018-08-15 05:29:21
BitMEX WebSocket | Header line. WebSocket-Server: uWebSockets | 2018-08-15 05:29:21
BitMEX WebSocket | Header line. Strict-Transport-Security: max-age=31536000; includeSubDomains | 2018-08-15 05:29:21
BitMEX WebSocket | Header line. | 2018-08-15 05:29:21
BitMEX WebSocket | Web socket state is now open. | 2018-08-15 05:29:21
BitMEX Trading Direct | Connected to data and trading server. | 2018-08-15 05:29:21
BitMEX WebSocket | WebSocket received OpCode Close. Received status code: 0 | 2018-08-15 05:29:21
BitMEX Trading Direct | WebSocket closed. | 2018-08-15 05:29:21
Connection to the external service has been lost. | 2018-08-15 05:29:21
BitMEX WebSocket socket (6) | Socket gracefully closed by remote side. | 2018-08-15 05:29:21
BitMEX WebSocket socket (6) | Received socket Close event. | 2018-08-15 05:29:21
BitMEX WebSocket socket (6) | Initiating close of socket by core. | 2018-08-15 05:29:21
BitMEX WebSocket | Network socket for WebSocket has been closed by remote side. | 2018-08-15 05:29:21
BitMEX WebSocket socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-15 05:29:21
BitMEX WebSocket socket (6) | Closed. | 2018-08-15 05:29:21
BitMEX WebSocket socket (0) | Ignored Send call based on current state. | 2018-08-15 05:29:21
BitMEX Trading Direct | Disconnected. | 2018-08-15 05:29:21
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:29:21
HTTPS connection to www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2018-08-15 05:29:21
HTTPS connection to www.sierrachart.com:443 (5) | Initiating close of socket by core. | 2018-08-15 05:29:21
HTTPS connection to www.sierrachart.com:443 (5) | Received socket Close event. | 2018-08-15 05:29:21
HTTPS connection to www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-15 05:29:21
HTTPS connection to www.sierrachart.com:443 (5) | Closed. | 2018-08-15 05:29:21
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-08-15 05:29:24
BitMEX WebSocket | Connecting to WebSocket server. | 2018-08-15 05:29:24
BitMEX WebSocket socket (7) | Creating socket. Using TLS 1.2. | 2018-08-15 05:29:25
BitMEX WebSocket socket (7) | Connecting to IP: 54.76.198.201. | 2018-08-15 05:29:25
BitMEX WebSocket | Opening WebSocket. | 2018-08-15 05:29:25
BitMEX WebSocket | Sending WebSocket handshake. | 2018-08-15 05:29:25
BitMEX WebSocket socket (7) | Received socket Close event. | 2018-08-15 05:29:26
BitMEX WebSocket socket (7) | Socket gracefully closed by remote side. | 2018-08-15 05:29:26
BitMEX WebSocket | Header line. HTTP/1.1 400 Bad Request | 2018-08-15 05:29:26
BitMEX WebSocket | WebSocket not connected. Handshake acknowledgment: HTTP/1.1 400 Bad Request | 2018-08-15 05:29:26
BitMEX Trading Direct | WebSocket closed. | 2018-08-15 05:29:26
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-15 05:29:26
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:29:26
BitMEX WebSocket | Header line. Server: awselb/2.0 | 2018-08-15 05:29:26
BitMEX WebSocket | Header line. Date: Wed, 15 Aug 2018 05:29:25 GMT | 2018-08-15 05:29:26
BitMEX WebSocket | Header line. Content-Type: text/html | 2018-08-15 05:29:26
BitMEX WebSocket | Header line. Content-Length: 138 | 2018-08-15 05:29:26
BitMEX WebSocket | Header line. Connection: close | 2018-08-15 05:29:26
BitMEX WebSocket | Header line. | 2018-08-15 05:29:26
BitMEX WebSocket | Web socket state is now open. | 2018-08-15 05:29:26
BitMEX Trading Direct | Connected to data and trading server. | 2018-08-15 05:29:26
BitMEX WebSocket | Extension reserve bits set and not supported. | 2018-08-15 05:29:26
Connection to the external service has been lost. | 2018-08-15 05:29:26
BitMEX WebSocket socket (7) | Initiating close of socket by core. | 2018-08-15 05:29:26
BitMEX WebSocket | Network socket for WebSocket has been closed by remote side. | 2018-08-15 05:29:26
BitMEX WebSocket socket (7) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-15 05:29:26
BitMEX WebSocket socket (7) | Closed. | 2018-08-15 05:29:26
BitMEX WebSocket socket (0) | Ignored Send call based on current state. | 2018-08-15 05:29:26
BitMEX Trading Direct | Disconnected. | 2018-08-15 05:29:26
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:29:26
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-08-15 05:29:29
BitMEX WebSocket | Connecting to WebSocket server. | 2018-08-15 05:29:29
BitMEX WebSocket socket (8) | Creating socket. Using TLS 1.2. | 2018-08-15 05:29:29
BitMEX WebSocket socket (8) | Connecting to IP: 54.76.198.201. | 2018-08-15 05:29:29
BitMEX WebSocket | Opening WebSocket. | 2018-08-15 05:29:29
BitMEX WebSocket | Sending WebSocket handshake. | 2018-08-15 05:29:29
BitMEX WebSocket socket (8) | Received socket Close event. | 2018-08-15 05:29:30
BitMEX WebSocket socket (8) | Socket gracefully closed by remote side. | 2018-08-15 05:29:30
BitMEX WebSocket | Header line. HTTP/1.1 400 Bad Request | 2018-08-15 05:29:30
BitMEX WebSocket | WebSocket not connected. Handshake acknowledgment: HTTP/1.1 400 Bad Request | 2018-08-15 05:29:30
BitMEX Trading Direct | WebSocket closed. | 2018-08-15 05:29:30
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-15 05:29:30
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:29:30
BitMEX WebSocket | Header line. Server: awselb/2.0 | 2018-08-15 05:29:30
BitMEX WebSocket | Header line. Date: Wed, 15 Aug 2018 05:29:30 GMT | 2018-08-15 05:29:30
BitMEX WebSocket | Header line. Content-Type: text/html | 2018-08-15 05:29:30
BitMEX WebSocket | Header line. Content-Length: 138 | 2018-08-15 05:29:30
BitMEX WebSocket | Header line. Connection: close | 2018-08-15 05:29:30
BitMEX WebSocket | Header line. | 2018-08-15 05:29:30
BitMEX WebSocket | Web socket state is now open. | 2018-08-15 05:29:30
BitMEX Trading Direct | Connected to data and trading server. | 2018-08-15 05:29:30
BitMEX WebSocket | Extension reserve bits set and not supported. | 2018-08-15 05:29:30
Connection to the external service has been lost. | 2018-08-15 05:29:30
BitMEX WebSocket socket (8) | Initiating close of socket by core. | 2018-08-15 05:29:30
BitMEX WebSocket | Network socket for WebSocket has been closed by remote side. | 2018-08-15 05:29:30
BitMEX WebSocket socket (8) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-15 05:29:30
BitMEX WebSocket socket (8) | Closed. | 2018-08-15 05:29:30
BitMEX WebSocket socket (0) | Ignored Send call based on current state. | 2018-08-15 05:29:30
BitMEX Trading Direct | Disconnected. | 2018-08-15 05:29:30
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:29:30
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-08-15 05:29:33
BitMEX WebSocket | Connecting to WebSocket server. | 2018-08-15 05:29:33
BitMEX WebSocket socket (9) | Creating socket. Using TLS 1.2. | 2018-08-15 05:29:33
BitMEX WebSocket socket (9) | Connecting to IP: 54.76.198.201. | 2018-08-15 05:29:33
BitMEX WebSocket | Opening WebSocket. | 2018-08-15 05:29:33
BitMEX WebSocket | Sending WebSocket handshake. | 2018-08-15 05:29:33
BitMEX WebSocket socket (9) | Socket gracefully closed by remote side. | 2018-08-15 05:29:34
BitMEX WebSocket socket (9) | Received socket Close event. | 2018-08-15 05:29:34
BitMEX WebSocket | Header line. HTTP/1.1 400 Bad Request | 2018-08-15 05:29:34
BitMEX WebSocket | WebSocket not connected. Handshake acknowledgment: HTTP/1.1 400 Bad Request | 2018-08-15 05:29:34
BitMEX Trading Direct | WebSocket closed. | 2018-08-15 05:29:34
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-15 05:29:34
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:29:34
BitMEX WebSocket | Header line. Server: awselb/2.0 | 2018-08-15 05:29:34
BitMEX WebSocket | Header line. Date: Wed, 15 Aug 2018 05:29:34 GMT | 2018-08-15 05:29:34
BitMEX WebSocket | Header line. Content-Type: text/html | 2018-08-15 05:29:34
BitMEX WebSocket | Header line. Content-Length: 138 | 2018-08-15 05:29:34
BitMEX WebSocket | Header line. Connection: close | 2018-08-15 05:29:34
BitMEX WebSocket | Header line. | 2018-08-15 05:29:34
BitMEX WebSocket | Web socket state is now open. | 2018-08-15 05:29:34
BitMEX Trading Direct | Connected to data and trading server. | 2018-08-15 05:29:34
BitMEX WebSocket | Extension reserve bits set and not supported. | 2018-08-15 05:29:34
Connection to the external service has been lost. | 2018-08-15 05:29:34
BitMEX WebSocket socket (9) | Initiating close of socket by core. | 2018-08-15 05:29:34
BitMEX WebSocket | Network socket for WebSocket has been closed by remote side. | 2018-08-15 05:29:34
BitMEX WebSocket socket (9) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-15 05:29:34
BitMEX WebSocket socket (9) | Closed. | 2018-08-15 05:29:34
BitMEX WebSocket socket (0) | Ignored Send call based on current state. | 2018-08-15 05:29:34
BitMEX Trading Direct | Disconnected. | 2018-08-15 05:29:34
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:29:34
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-08-15 05:29:37
BitMEX WebSocket | Connecting to WebSocket server. | 2018-08-15 05:29:37
BitMEX WebSocket socket (10) | Creating socket. Using TLS 1.2. | 2018-08-15 05:29:37
BitMEX WebSocket socket (10) | Connecting to IP: 54.76.198.201. | 2018-08-15 05:29:37
BitMEX WebSocket | Opening WebSocket. | 2018-08-15 05:29:38
BitMEX WebSocket | Sending WebSocket handshake. | 2018-08-15 05:29:38
BitMEX WebSocket socket (10) | Socket gracefully closed by remote side. | 2018-08-15 05:29:39
BitMEX WebSocket socket (10) | Received socket Close event. | 2018-08-15 05:29:39
BitMEX WebSocket | Header line. HTTP/1.1 400 Bad Request | 2018-08-15 05:29:39
BitMEX WebSocket | WebSocket not connected. Handshake acknowledgment: HTTP/1.1 400 Bad Request | 2018-08-15 05:29:39
BitMEX Trading Direct | WebSocket closed. | 2018-08-15 05:29:39
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-15 05:29:39
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:29:39
BitMEX WebSocket | Header line. Server: awselb/2.0 | 2018-08-15 05:29:39
BitMEX WebSocket | Header line. Date: Wed, 15 Aug 2018 05:29:38 GMT | 2018-08-15 05:29:39
BitMEX WebSocket | Header line. Content-Type: text/html | 2018-08-15 05:29:39
BitMEX WebSocket | Header line. Content-Length: 138 | 2018-08-15 05:29:39
BitMEX WebSocket | Header line. Connection: close | 2018-08-15 05:29:39
BitMEX WebSocket | Header line. | 2018-08-15 05:29:39
BitMEX WebSocket | Web socket state is now open. | 2018-08-15 05:29:39
BitMEX Trading Direct | Connected to data and trading server. | 2018-08-15 05:29:39
BitMEX WebSocket | Extension reserve bits set and not supported. | 2018-08-15 05:29:39
Connection to the external service has been lost. | 2018-08-15 05:29:39
BitMEX WebSocket socket (10) | Initiating close of socket by core. | 2018-08-15 05:29:39
BitMEX WebSocket | Network socket for WebSocket has been closed by remote side. | 2018-08-15 05:29:39
BitMEX WebSocket socket (10) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-15 05:29:39
BitMEX WebSocket socket (10) | Closed. | 2018-08-15 05:29:39
BitMEX WebSocket socket (0) | Ignored Send call based on current state. | 2018-08-15 05:29:39
BitMEX Trading Direct | Disconnected. | 2018-08-15 05:29:39
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:29:39
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-08-15 05:29:42
BitMEX WebSocket | Connecting to WebSocket server. | 2018-08-15 05:29:42
BitMEX WebSocket socket (11) | Creating socket. Using TLS 1.2. | 2018-08-15 05:29:42
BitMEX WebSocket socket (11) | Connecting to IP: 54.76.198.201. | 2018-08-15 05:29:42
BitMEX WebSocket | Opening WebSocket. | 2018-08-15 05:29:42
BitMEX WebSocket | Sending WebSocket handshake. | 2018-08-15 05:29:42
BitMEX WebSocket socket (11) | Socket gracefully closed by remote side. | 2018-08-15 05:29:43
BitMEX WebSocket socket (11) | Received socket Close event. | 2018-08-15 05:29:43
BitMEX WebSocket | Header line. HTTP/1.1 400 Bad Request | 2018-08-15 05:29:43
BitMEX WebSocket | WebSocket not connected. Handshake acknowledgment: HTTP/1.1 400 Bad Request | 2018-08-15 05:29:43
BitMEX Trading Direct | WebSocket closed. | 2018-08-15 05:29:43
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-15 05:29:43
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:29:43
BitMEX WebSocket | Header line. Server: awselb/2.0 | 2018-08-15 05:29:43
BitMEX WebSocket | Header line. Date: Wed, 15 Aug 2018 05:29:42 GMT | 2018-08-15 05:29:43
BitMEX WebSocket | Header line. Content-Type: text/html | 2018-08-15 05:29:43
BitMEX WebSocket | Header line. Content-Length: 138 | 2018-08-15 05:29:43
BitMEX WebSocket | Header line. Connection: close | 2018-08-15 05:29:43
BitMEX WebSocket | Header line. | 2018-08-15 05:29:43
BitMEX WebSocket | Web socket state is now open. | 2018-08-15 05:29:43
BitMEX Trading Direct | Connected to data and trading server. | 2018-08-15 05:29:43
BitMEX WebSocket | Extension reserve bits set and not supported. | 2018-08-15 05:29:43
Connection to the external service has been lost. | 2018-08-15 05:29:43
BitMEX WebSocket socket (11) | Initiating close of socket by core. | 2018-08-15 05:29:43
BitMEX WebSocket | Network socket for WebSocket has been closed by remote side. | 2018-08-15 05:29:43
BitMEX WebSocket socket (11) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-15 05:29:43
BitMEX WebSocket socket (11) | Closed. | 2018-08-15 05:29:43
BitMEX WebSocket socket (0) | Ignored Send call based on current state. | 2018-08-15 05:29:43
BitMEX Trading Direct | Disconnected. | 2018-08-15 05:29:43
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:29:43
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-08-15 05:29:46
BitMEX WebSocket | Connecting to WebSocket server. | 2018-08-15 05:29:46
BitMEX WebSocket socket (12) | Creating socket. Using TLS 1.2. | 2018-08-15 05:29:46
BitMEX WebSocket socket (12) | Connecting to IP: 54.76.198.201. | 2018-08-15 05:29:46
BitMEX WebSocket | Opening WebSocket. | 2018-08-15 05:29:46
BitMEX WebSocket | Sending WebSocket handshake. | 2018-08-15 05:29:46
BitMEX WebSocket socket (12) | Socket gracefully closed by remote side. | 2018-08-15 05:29:47
BitMEX WebSocket socket (12) | Received socket Close event. | 2018-08-15 05:29:47
BitMEX WebSocket | Header line. HTTP/1.1 400 Bad Request | 2018-08-15 05:29:47
BitMEX WebSocket | WebSocket not connected. Handshake acknowledgment: HTTP/1.1 400 Bad Request | 2018-08-15 05:29:47
BitMEX Trading Direct | WebSocket closed. | 2018-08-15 05:29:47
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-15 05:29:47
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:29:47
BitMEX WebSocket | Header line. Server: awselb/2.0 | 2018-08-15 05:29:47
BitMEX WebSocket | Header line. Date: Wed, 15 Aug 2018 05:29:46 GMT | 2018-08-15 05:29:47
BitMEX WebSocket | Header line. Content-Type: text/html | 2018-08-15 05:29:47
BitMEX WebSocket | Header line. Content-Length: 138 | 2018-08-15 05:29:47
BitMEX WebSocket | Header line. Connection: close | 2018-08-15 05:29:47
BitMEX WebSocket | Header line. | 2018-08-15 05:29:47
BitMEX WebSocket | Web socket state is now open. | 2018-08-15 05:29:47
BitMEX Trading Direct | Connected to data and trading server. | 2018-08-15 05:29:47
BitMEX WebSocket | Extension reserve bits set and not supported. | 2018-08-15 05:29:47
Connection to the external service has been lost. | 2018-08-15 05:29:47
BitMEX WebSocket socket (12) | Initiating close of socket by core. | 2018-08-15 05:29:47
BitMEX WebSocket | Network socket for WebSocket has been closed by remote side. | 2018-08-15 05:29:47
BitMEX WebSocket socket (12) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-15 05:29:47
BitMEX WebSocket socket (12) | Closed. | 2018-08-15 05:29:47
BitMEX WebSocket socket (0) | Ignored Send call based on current state. | 2018-08-15 05:29:47
BitMEX Trading Direct | Disconnected. | 2018-08-15 05:29:47
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:29:47
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-08-15 05:29:50
BitMEX WebSocket | Connecting to WebSocket server. | 2018-08-15 05:29:50
BitMEX WebSocket socket (13) | Creating socket. Using TLS 1.2. | 2018-08-15 05:29:50
BitMEX WebSocket socket (13) | Connecting to IP: 54.76.198.201. | 2018-08-15 05:29:50
BitMEX WebSocket | Opening WebSocket. | 2018-08-15 05:29:50
BitMEX WebSocket | Sending WebSocket handshake. | 2018-08-15 05:29:50
BitMEX WebSocket socket (13) | Socket gracefully closed by remote side. | 2018-08-15 05:29:51
BitMEX WebSocket | Header line. HTTP/1.1 400 Bad Request | 2018-08-15 05:29:51
BitMEX WebSocket | WebSocket not connected. Handshake acknowledgment: HTTP/1.1 400 Bad Request | 2018-08-15 05:29:51
BitMEX WebSocket socket (13) | Received socket Close event. | 2018-08-15 05:29:51
BitMEX Trading Direct | WebSocket closed. | 2018-08-15 05:29:51
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-15 05:29:51
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:29:51
BitMEX WebSocket | Header line. Server: awselb/2.0 | 2018-08-15 05:29:51
BitMEX WebSocket | Header line. Date: Wed, 15 Aug 2018 05:29:51 GMT | 2018-08-15 05:29:51
BitMEX WebSocket | Header line. Content-Type: text/html | 2018-08-15 05:29:51
BitMEX WebSocket | Header line. Content-Length: 138 | 2018-08-15 05:29:51
BitMEX WebSocket | Header line. Connection: close | 2018-08-15 05:29:51
BitMEX WebSocket | Header line. | 2018-08-15 05:29:51
BitMEX WebSocket | Web socket state is now open. | 2018-08-15 05:29:51
BitMEX Trading Direct | Connected to data and trading server. | 2018-08-15 05:29:51
BitMEX WebSocket | Extension reserve bits set and not supported. | 2018-08-15 05:29:51
Connection to the external service has been lost. | 2018-08-15 05:29:51
BitMEX WebSocket socket (13) | Initiating close of socket by core. | 2018-08-15 05:29:51
BitMEX WebSocket | Network socket for WebSocket has been closed by remote side. | 2018-08-15 05:29:51
BitMEX WebSocket socket (13) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-15 05:29:51
BitMEX WebSocket socket (13) | Closed. | 2018-08-15 05:29:51
BitMEX WebSocket socket (0) | Ignored Send call based on current state. | 2018-08-15 05:29:51
BitMEX Trading Direct | Disconnected. | 2018-08-15 05:29:51
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:29:51
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-08-15 05:29:53
BitMEX WebSocket | Connecting to WebSocket server. | 2018-08-15 05:29:53
BitMEX WebSocket socket (14) | Creating socket. Using TLS 1.2. | 2018-08-15 05:29:53
BitMEX WebSocket socket (14) | Connecting to IP: 54.76.198.201. | 2018-08-15 05:29:53
BitMEX WebSocket | Opening WebSocket. | 2018-08-15 05:29:54
BitMEX WebSocket | Sending WebSocket handshake. | 2018-08-15 05:29:54
BitMEX WebSocket socket (14) | Socket gracefully closed by remote side. | 2018-08-15 05:29:55
BitMEX WebSocket | Header line. HTTP/1.1 400 Bad Request | 2018-08-15 05:29:55
BitMEX WebSocket | WebSocket not connected. Handshake acknowledgment: HTTP/1.1 400 Bad Request | 2018-08-15 05:29:55
BitMEX Trading Direct | WebSocket closed. | 2018-08-15 05:29:55
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-15 05:29:55
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:29:55
BitMEX WebSocket socket (14) | Received socket Close event. | 2018-08-15 05:29:55
BitMEX WebSocket | Header line. Server: awselb/2.0 | 2018-08-15 05:29:55
BitMEX WebSocket | Header line. Date: Wed, 15 Aug 2018 05:29:54 GMT | 2018-08-15 05:29:55
BitMEX WebSocket | Header line. Content-Type: text/html | 2018-08-15 05:29:55
BitMEX WebSocket | Header line. Content-Length: 138 | 2018-08-15 05:29:55
BitMEX WebSocket | Header line. Connection: close | 2018-08-15 05:29:55
BitMEX WebSocket | Header line. | 2018-08-15 05:29:55
BitMEX WebSocket | Web socket state is now open. | 2018-08-15 05:29:55
BitMEX Trading Direct | Connected to data and trading server. | 2018-08-15 05:29:55
BitMEX WebSocket | Extension reserve bits set and not supported. | 2018-08-15 05:29:55
Connection to the external service has been lost. | 2018-08-15 05:29:55
BitMEX WebSocket socket (14) | Initiating close of socket by core. | 2018-08-15 05:29:55
BitMEX WebSocket | Network socket for WebSocket has been closed by remote side. | 2018-08-15 05:29:55
BitMEX WebSocket socket (14) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-15 05:29:55
BitMEX WebSocket socket (14) | Closed. | 2018-08-15 05:29:55
BitMEX WebSocket socket (0) | Ignored Send call based on current state. | 2018-08-15 05:29:55
BitMEX Trading Direct | Disconnected. | 2018-08-15 05:29:55
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:29:55
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-08-15 05:29:58
BitMEX WebSocket | Connecting to WebSocket server. | 2018-08-15 05:29:58
BitMEX WebSocket socket (15) | Creating socket. Using TLS 1.2. | 2018-08-15 05:29:58
BitMEX WebSocket socket (15) | Connecting to IP: 54.76.198.201. | 2018-08-15 05:29:58
BitMEX WebSocket | Opening WebSocket. | 2018-08-15 05:29:58
BitMEX WebSocket | Sending WebSocket handshake. | 2018-08-15 05:29:58
BitMEX WebSocket | Header line. HTTP/1.1 400 Bad Request | 2018-08-15 05:29:59
BitMEX WebSocket socket (15) | Socket gracefully closed by remote side. | 2018-08-15 05:29:59
BitMEX WebSocket | WebSocket not connected. Handshake acknowledgment: HTTP/1.1 400 Bad Request | 2018-08-15 05:29:59
BitMEX WebSocket socket (15) | Received socket Close event. | 2018-08-15 05:29:59
BitMEX Trading Direct | WebSocket closed. | 2018-08-15 05:29:59
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-15 05:29:59
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:29:59
BitMEX WebSocket | Header line. Server: awselb/2.0 | 2018-08-15 05:29:59
BitMEX WebSocket | Header line. Date: Wed, 15 Aug 2018 05:29:58 GMT | 2018-08-15 05:29:59
BitMEX WebSocket | Header line. Content-Type: text/html | 2018-08-15 05:29:59
BitMEX WebSocket | Header line. Content-Length: 138 | 2018-08-15 05:29:59
BitMEX WebSocket | Header line. Connection: close | 2018-08-15 05:29:59
BitMEX WebSocket | Header line. | 2018-08-15 05:29:59
BitMEX WebSocket | Web socket state is now open. | 2018-08-15 05:29:59
BitMEX Trading Direct | Connected to data and trading server. | 2018-08-15 05:29:59
BitMEX WebSocket | Extension reserve bits set and not supported. | 2018-08-15 05:29:59
Connection to the external service has been lost. | 2018-08-15 05:29:59
BitMEX WebSocket socket (15) | Initiating close of socket by core. | 2018-08-15 05:29:59
BitMEX WebSocket | Network socket for WebSocket has been closed by remote side. | 2018-08-15 05:29:59
BitMEX WebSocket socket (15) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-15 05:29:59
BitMEX WebSocket socket (15) | Closed. | 2018-08-15 05:29:59
BitMEX WebSocket socket (0) | Ignored Send call based on current state. | 2018-08-15 05:29:59
BitMEX Trading Direct | Disconnected. | 2018-08-15 05:29:59
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:29:59
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-08-15 05:30:02
BitMEX WebSocket | Connecting to WebSocket server. | 2018-08-15 05:30:02
BitMEX WebSocket socket (16) | Creating socket. Using TLS 1.2. | 2018-08-15 05:30:02
BitMEX WebSocket socket (16) | Connecting to IP: 54.76.198.201. | 2018-08-15 05:30:02
BitMEX WebSocket | Opening WebSocket. | 2018-08-15 05:30:02
BitMEX WebSocket | Sending WebSocket handshake. | 2018-08-15 05:30:02
BitMEX WebSocket socket (16) | Received socket Close event. | 2018-08-15 05:30:03
BitMEX WebSocket socket (16) | Socket gracefully closed by remote side. | 2018-08-15 05:30:03
BitMEX WebSocket | Header line. HTTP/1.1 400 Bad Request | 2018-08-15 05:30:03
BitMEX WebSocket | WebSocket not connected. Handshake acknowledgment: HTTP/1.1 400 Bad Request | 2018-08-15 05:30:03
BitMEX Trading Direct | WebSocket closed. | 2018-08-15 05:30:03
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-15 05:30:03
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:30:03
BitMEX WebSocket | Header line. Server: awselb/2.0 | 2018-08-15 05:30:03
BitMEX WebSocket | Header line. Date: Wed, 15 Aug 2018 05:30:02 GMT | 2018-08-15 05:30:03
BitMEX WebSocket | Header line. Content-Type: text/html | 2018-08-15 05:30:03
BitMEX WebSocket | Header line. Content-Length: 138 | 2018-08-15 05:30:03
BitMEX WebSocket | Header line. Connection: close | 2018-08-15 05:30:03
BitMEX WebSocket | Header line. | 2018-08-15 05:30:03
BitMEX WebSocket | Web socket state is now open. | 2018-08-15 05:30:03
BitMEX Trading Direct | Connected to data and trading server. | 2018-08-15 05:30:03
BitMEX WebSocket | Extension reserve bits set and not supported. | 2018-08-15 05:30:03
Connection to the external service has been lost. | 2018-08-15 05:30:03
BitMEX WebSocket socket (16) | Initiating close of socket by core. | 2018-08-15 05:30:03
BitMEX WebSocket | Network socket for WebSocket has been closed by remote side. | 2018-08-15 05:30:03
BitMEX WebSocket socket (16) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-15 05:30:03
BitMEX WebSocket socket (16) | Closed. | 2018-08-15 05:30:03
BitMEX WebSocket socket (0) | Ignored Send call based on current state. | 2018-08-15 05:30:03
BitMEX Trading Direct | Disconnected. | 2018-08-15 05:30:03
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:30:03
XBTUSD-BMEX #1 | Reloading chart. | 2018-08-15 05:30:06
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-08-15 05:30:06
BitMEX WebSocket | Connecting to WebSocket server. | 2018-08-15 05:30:06
BitMEX WebSocket socket (17) | Creating socket. Using TLS 1.2. | 2018-08-15 05:30:06
BitMEX WebSocket socket (17) | Connecting to IP: 54.76.198.201. | 2018-08-15 05:30:06
Intraday data recording state for symbol XBTUSD-BMEX is set to download 'Pending'. | 2018-08-15 05:30:06
HD Request # 2 | Downloading Intraday chart data for XBTUSD-BMEX to the file XBTUSD-BMEX.scid. Service: bitmex | 2018-08-15 05:30:06
HD Request # 2 | Download start date-time: 2018-08-08 04:59:41.000 | 2018-08-15 05:30:06
HD Request # 2 | Using server: ds4.sierracharts.com port 10149 | 2018-08-15 05:30:06
Socket (18) | Creating socket. | 2018-08-15 05:30:06
Socket (18) | Connecting to IP: 192.81.56.146. | 2018-08-15 05:30:06
BitMEX WebSocket | Opening WebSocket. | 2018-08-15 05:30:06
BitMEX WebSocket | Sending WebSocket handshake. | 2018-08-15 05:30:06
HD Request # 2 | Setting DTC encoding to Binary VLS | 2018-08-15 05:30:07
HD Request # 2 | Sending historical data logon request message. | 2018-08-15 05:30:07
HD Request # 2 | Requesting Intraday data. Start date-time: 2018-08-08 04:59:41. Record interval: 1. Symbol: XBTUSD-BMEX | 2018-08-15 05:30:07
BitMEX WebSocket socket (17) | Received socket Close event. | 2018-08-15 05:30:07
BitMEX WebSocket socket (17) | Socket gracefully closed by remote side. | 2018-08-15 05:30:07
BitMEX WebSocket | Header line. HTTP/1.1 400 Bad Request | 2018-08-15 05:30:07
BitMEX WebSocket | WebSocket not connected. Handshake acknowledgment: HTTP/1.1 400 Bad Request | 2018-08-15 05:30:07
BitMEX Trading Direct | WebSocket closed. | 2018-08-15 05:30:07
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-15 05:30:07
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:30:07
BitMEX WebSocket | Header line. Server: awselb/2.0 | 2018-08-15 05:30:07
BitMEX WebSocket | Header line. Date: Wed, 15 Aug 2018 05:30:07 GMT | 2018-08-15 05:30:07
BitMEX WebSocket | Header line. Content-Type: text/html | 2018-08-15 05:30:07
BitMEX WebSocket | Header line. Content-Length: 138 | 2018-08-15 05:30:07
BitMEX WebSocket | Header line. Connection: close | 2018-08-15 05:30:07
BitMEX WebSocket | Header line. | 2018-08-15 05:30:07
BitMEX WebSocket | Web socket state is now open. | 2018-08-15 05:30:07
BitMEX Trading Direct | Connected to data and trading server. | 2018-08-15 05:30:07
BitMEX WebSocket | Extension reserve bits set and not supported. | 2018-08-15 05:30:07
Connection to the external service has been lost. | 2018-08-15 05:30:07
BitMEX WebSocket socket (17) | Initiating close of socket by core. | 2018-08-15 05:30:07
BitMEX WebSocket | Network socket for WebSocket has been closed by remote side. | 2018-08-15 05:30:07
BitMEX WebSocket socket (17) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-15 05:30:07
BitMEX WebSocket socket (17) | Closed. | 2018-08-15 05:30:07
BitMEX WebSocket socket (0) | Ignored Send call based on current state. | 2018-08-15 05:30:07
BitMEX Trading Direct | Disconnected. | 2018-08-15 05:30:07
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:30:07
HD Request # 2 | Decompressing data. | 2018-08-15 05:30:07
HD Request # 2 | Receiving Intraday data for XBTUSD-BMEX starting at 2018-08-08 04:59:41 | 2018-08-15 05:30:08
HD Request # 2 | Timestamp of first Intraday data file record written: 2018-08-08 04:59:41 | 2018-08-15 05:30:08
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-08-15 05:30:10
BitMEX WebSocket | Connecting to WebSocket server. | 2018-08-15 05:30:10
BitMEX WebSocket socket (19) | Creating socket. Using TLS 1.2. | 2018-08-15 05:30:10
BitMEX WebSocket socket (19) | Connecting to IP: 54.76.198.201. | 2018-08-15 05:30:10
BitMEX WebSocket | Opening WebSocket. | 2018-08-15 05:30:10
BitMEX WebSocket | Sending WebSocket handshake. | 2018-08-15 05:30:10
BitMEX WebSocket | Header line. HTTP/1.1 400 Bad Request | 2018-08-15 05:30:11
BitMEX WebSocket | WebSocket not connected. Handshake acknowledgment: HTTP/1.1 400 Bad Request | 2018-08-15 05:30:11
BitMEX WebSocket socket (19) | Received socket Close event. | 2018-08-15 05:30:11
BitMEX Trading Direct | WebSocket closed. | 2018-08-15 05:30:11
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-15 05:30:11
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:30:11
BitMEX WebSocket socket (19) | Socket gracefully closed by remote side. | 2018-08-15 05:30:11
BitMEX WebSocket | Header line. Server: awselb/2.0 | 2018-08-15 05:30:11
BitMEX WebSocket | Header line. Date: Wed, 15 Aug 2018 05:30:11 GMT | 2018-08-15 05:30:11
BitMEX WebSocket | Header line. Content-Type: text/html | 2018-08-15 05:30:11
BitMEX WebSocket | Header line. Content-Length: 138 | 2018-08-15 05:30:11
BitMEX WebSocket | Header line. Connection: close | 2018-08-15 05:30:11
BitMEX WebSocket | Header line. | 2018-08-15 05:30:11
BitMEX WebSocket | Web socket state is now open. | 2018-08-15 05:30:11
BitMEX Trading Direct | Connected to data and trading server. | 2018-08-15 05:30:11
BitMEX WebSocket | Extension reserve bits set and not supported. | 2018-08-15 05:30:11
Connection to the external service has been lost. | 2018-08-15 05:30:11
BitMEX WebSocket socket (19) | Initiating close of socket by core. | 2018-08-15 05:30:11
BitMEX WebSocket | Network socket for WebSocket has been closed by remote side. | 2018-08-15 05:30:11
BitMEX WebSocket socket (19) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-15 05:30:11
BitMEX WebSocket socket (19) | Closed. | 2018-08-15 05:30:11
BitMEX WebSocket socket (0) | Ignored Send call based on current state. | 2018-08-15 05:30:11
BitMEX Trading Direct | Disconnected. | 2018-08-15 05:30:11
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:30:11
HD Request # 2 | Historical data for XBTUSD-BMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-08-15 05:30:14
Socket (18) | Initiating close of socket by core. | 2018-08-15 05:30:14
Historical data download thread signaled to stop. | 2018-08-15 05:30:14
Socket (18) | Shutdown started. Waiting for graceful close. | 2018-08-15 05:30:14
HD Request # 2 | Received 458775 records from 2018-08-08 04:59:41 to 2018-08-15 05:30:07 (7.0 days) and wrote 458775 records for XBTUSD-BMEX | 2018-08-15 05:30:14
HD Request # 2 | Completion time: 8s | 2018-08-15 05:30:14
HD Request # 2 | Intraday data download complete for XBTUSD-BMEX. Unique request ID: 1 | 2018-08-15 05:30:14
Removed historical data download ID 1 | 2018-08-15 05:30:14
Socket (18) | Socket gracefully closed by remote side. | 2018-08-15 05:30:14
Socket (18) | Closed. | 2018-08-15 05:30:14
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-08-15 05:30:14
BitMEX WebSocket | Connecting to WebSocket server. | 2018-08-15 05:30:14
BitMEX WebSocket socket (21) | Creating socket. Using TLS 1.2. | 2018-08-15 05:30:14
BitMEX WebSocket socket (21) | Connecting to IP: 54.76.198.201. | 2018-08-15 05:30:14
BitMEX WebSocket | Opening WebSocket. | 2018-08-15 05:30:15
BitMEX WebSocket | Sending WebSocket handshake. | 2018-08-15 05:30:15
BitMEX WebSocket socket (21) | Socket gracefully closed by remote side. | 2018-08-15 05:30:16
BitMEX WebSocket socket (21) | Received socket Close event. | 2018-08-15 05:30:16
BitMEX WebSocket | Header line. HTTP/1.1 400 Bad Request | 2018-08-15 05:30:16
BitMEX WebSocket | WebSocket not connected. Handshake acknowledgment: HTTP/1.1 400 Bad Request | 2018-08-15 05:30:16
BitMEX Trading Direct | WebSocket closed. | 2018-08-15 05:30:16
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-15 05:30:16
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:30:16
BitMEX WebSocket | Header line. Server: awselb/2.0 | 2018-08-15 05:30:16
BitMEX WebSocket | Header line. Date: Wed, 15 Aug 2018 05:30:15 GMT | 2018-08-15 05:30:16
BitMEX WebSocket | Header line. Content-Type: text/html | 2018-08-15 05:30:16
BitMEX WebSocket | Header line. Content-Length: 138 | 2018-08-15 05:30:16
BitMEX WebSocket | Header line. Connection: close | 2018-08-15 05:30:16
BitMEX WebSocket | Header line. | 2018-08-15 05:30:16
BitMEX WebSocket | Web socket state is now open. | 2018-08-15 05:30:16
BitMEX Trading Direct | Connected to data and trading server. | 2018-08-15 05:30:16
BitMEX WebSocket | Extension reserve bits set and not supported. | 2018-08-15 05:30:16
Connection to the external service has been lost. | 2018-08-15 05:30:16
BitMEX WebSocket socket (21) | Initiating close of socket by core. | 2018-08-15 05:30:16
BitMEX WebSocket | Network socket for WebSocket has been closed by remote side. | 2018-08-15 05:30:16
BitMEX WebSocket socket (21) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-15 05:30:16
BitMEX WebSocket socket (21) | Closed. | 2018-08-15 05:30:16
BitMEX WebSocket socket (0) | Ignored Send call based on current state. | 2018-08-15 05:30:16
BitMEX Trading Direct | Disconnected. | 2018-08-15 05:30:16
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:30:16
Intraday data recording state for symbol XBTUSD-BMEX is set to download 'Pending'. | 2018-08-15 05:30:16
HD Request # 3 | Downloading Intraday chart data for XBTUSD-BMEX to the file XBTUSD-BMEX.scid. Service: bitmex | 2018-08-15 05:30:16
HD Request # 3 | Download start date-time: 2018-08-15 05:30:07.000 | 2018-08-15 05:30:16
HD Request # 3 | Using server: ds3.sierracharts.com port 10150 | 2018-08-15 05:30:16
Socket (22) | Creating socket. | 2018-08-15 05:30:16
Socket (22) | Connecting to IP: 65.182.172.42. | 2018-08-15 05:30:16
HD Request # 3 | Setting DTC encoding to Binary VLS | 2018-08-15 05:30:17
HD Request # 3 | Sending historical data logon request message. | 2018-08-15 05:30:17
HD Request # 3 | Requesting Intraday data. Start date-time: 2018-08-15 05:30:07. Record interval: 1. Symbol: XBTUSD-BMEX | 2018-08-15 05:30:17
HD Request # 3 | Decompressing data. | 2018-08-15 05:30:17
HD Request # 3 | Receiving Intraday data for XBTUSD-BMEX starting at 2018-08-15 05:30:07 | 2018-08-15 05:30:17
HD Request # 3 | Timestamp of first Intraday data file record written: 2018-08-15 05:30:07 | 2018-08-15 05:30:17
Socket (22) | Initiating close of socket by core. | 2018-08-15 05:30:17
HD Request # 3 | Historical data for XBTUSD-BMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-08-15 05:30:17
Socket (22) | Shutdown started. Waiting for graceful close. | 2018-08-15 05:30:17
Historical data download thread signaled to stop. | 2018-08-15 05:30:17
HD Request # 3 | Received 8 records from 2018-08-15 05:30:07 to 2018-08-15 05:30:14 (7.0 seconds) and wrote 8 records for XBTUSD-BMEX | 2018-08-15 05:30:17
HD Request # 3 | Completion time: 2s | 2018-08-15 05:30:17
HD Request # 3 | Intraday data download complete for XBTUSD-BMEX. Unique request ID: 2 | 2018-08-15 05:30:17
Removed historical data download ID 2 | 2018-08-15 05:30:17
Socket (22) | Socket gracefully closed by remote side. | 2018-08-15 05:30:17
Socket (22) | Closed. | 2018-08-15 05:30:17
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-08-15 05:30:19
BitMEX WebSocket | Connecting to WebSocket server. | 2018-08-15 05:30:19
BitMEX WebSocket socket (23) | Creating socket. Using TLS 1.2. | 2018-08-15 05:30:19
BitMEX WebSocket socket (23) | Connecting to IP: 54.76.198.201. | 2018-08-15 05:30:19
BitMEX WebSocket | Opening WebSocket. | 2018-08-15 05:30:19
BitMEX WebSocket | Sending WebSocket handshake. | 2018-08-15 05:30:19
BitMEX WebSocket socket (23) | Socket gracefully closed by remote side. | 2018-08-15 05:30:20
BitMEX WebSocket | Header line. HTTP/1.1 400 Bad Request | 2018-08-15 05:30:20
BitMEX WebSocket | WebSocket not connected. Handshake acknowledgment: HTTP/1.1 400 Bad Request | 2018-08-15 05:30:20
BitMEX Trading Direct | WebSocket closed. | 2018-08-15 05:30:20
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-15 05:30:20
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:30:20
BitMEX WebSocket socket (23) | Received socket Close event. | 2018-08-15 05:30:20
BitMEX WebSocket | Header line. Server: awselb/2.0 | 2018-08-15 05:30:20
BitMEX WebSocket | Header line. Date: Wed, 15 Aug 2018 05:30:19 GMT | 2018-08-15 05:30:20
BitMEX WebSocket | Header line. Content-Type: text/html | 2018-08-15 05:30:20
BitMEX WebSocket | Header line. Content-Length: 138 | 2018-08-15 05:30:20
BitMEX WebSocket | Header line. Connection: close | 2018-08-15 05:30:20
BitMEX WebSocket | Header line. | 2018-08-15 05:30:20
BitMEX WebSocket | Web socket state is now open. | 2018-08-15 05:30:20
BitMEX Trading Direct | Connected to data and trading server. | 2018-08-15 05:30:20
BitMEX WebSocket | Extension reserve bits set and not supported. | 2018-08-15 05:30:20
Connection to the external service has been lost. | 2018-08-15 05:30:20
BitMEX WebSocket socket (23) | Initiating close of socket by core. | 2018-08-15 05:30:20
BitMEX WebSocket | Network socket for WebSocket has been closed by remote side. | 2018-08-15 05:30:20
BitMEX WebSocket socket (23) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-15 05:30:20
BitMEX WebSocket socket (23) | Closed. | 2018-08-15 05:30:20
BitMEX WebSocket socket (0) | Ignored Send call based on current state. | 2018-08-15 05:30:20
BitMEX Trading Direct | Disconnected. | 2018-08-15 05:30:20
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:30:20
Intraday data recording state for symbol XBTUSD-BMEX is set to download 'Pending'. | 2018-08-15 05:30:20
HD Request # 4 | Downloading Intraday chart data for XBTUSD-BMEX to the file XBTUSD-BMEX.scid. Service: bitmex | 2018-08-15 05:30:20
HD Request # 4 | Download start date-time: 2018-08-15 05:30:14.000 | 2018-08-15 05:30:20
HD Request # 4 | Using server: ds4.sierracharts.com port 10149 | 2018-08-15 05:30:20
Socket (24) | Creating socket. | 2018-08-15 05:30:20
Socket (24) | Connecting to IP: 192.81.56.146. | 2018-08-15 05:30:20
HD Request # 4 | Setting DTC encoding to Binary VLS | 2018-08-15 05:30:20
HD Request # 4 | Sending historical data logon request message. | 2018-08-15 05:30:20
HD Request # 4 | Requesting Intraday data. Start date-time: 2018-08-15 05:30:14. Record interval: 1. Symbol: XBTUSD-BMEX | 2018-08-15 05:30:21
HD Request # 4 | Decompressing data. | 2018-08-15 05:30:21
HD Request # 4 | Receiving Intraday data for XBTUSD-BMEX starting at 2018-08-15 05:30:14 | 2018-08-15 05:30:21
HD Request # 4 | Timestamp of first Intraday data file record written: 2018-08-15 05:30:14 | 2018-08-15 05:30:21
Socket (24) | Initiating close of socket by core. | 2018-08-15 05:30:21
Socket (24) | Shutdown started. Waiting for graceful close. | 2018-08-15 05:30:21
HD Request # 4 | Historical data for XBTUSD-BMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-08-15 05:30:21
Historical data download thread signaled to stop. | 2018-08-15 05:30:21
HD Request # 4 | Received 6 records from 2018-08-15 05:30:14 to 2018-08-15 05:30:20 (6.0 seconds) and wrote 6 records for XBTUSD-BMEX | 2018-08-15 05:30:21
HD Request # 4 | Completion time: 1s | 2018-08-15 05:30:21
HD Request # 4 | Intraday data download complete for XBTUSD-BMEX. Unique request ID: 3 | 2018-08-15 05:30:21
Removed historical data download ID 3 | 2018-08-15 05:30:21
Socket (24) | Socket gracefully closed by remote side. | 2018-08-15 05:30:21
Socket (24) | Closed. | 2018-08-15 05:30:21
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-08-15 05:30:23
BitMEX WebSocket | Connecting to WebSocket server. | 2018-08-15 05:30:23
BitMEX WebSocket socket (25) | Creating socket. Using TLS 1.2. | 2018-08-15 05:30:23
BitMEX WebSocket socket (25) | Connecting to IP: 54.76.198.201. | 2018-08-15 05:30:23
BitMEX WebSocket | Opening WebSocket. | 2018-08-15 05:30:23
BitMEX WebSocket | Sending WebSocket handshake. | 2018-08-15 05:30:23
BitMEX WebSocket | Header line. HTTP/1.1 400 Bad Request | 2018-08-15 05:30:24
BitMEX WebSocket | WebSocket not connected. Handshake acknowledgment: HTTP/1.1 400 Bad Request | 2018-08-15 05:30:24
BitMEX Trading Direct | WebSocket closed. | 2018-08-15 05:30:24
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-15 05:30:24
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:30:24
BitMEX WebSocket socket (25) | Socket gracefully closed by remote side. | 2018-08-15 05:30:24
BitMEX WebSocket socket (25) | Received socket Close event. | 2018-08-15 05:30:24
BitMEX WebSocket | Header line. Server: awselb/2.0 | 2018-08-15 05:30:24
BitMEX WebSocket | Header line. Date: Wed, 15 Aug 2018 05:30:24 GMT | 2018-08-15 05:30:24
BitMEX WebSocket | Header line. Content-Type: text/html | 2018-08-15 05:30:24
BitMEX WebSocket | Header line. Content-Length: 138 | 2018-08-15 05:30:24
BitMEX WebSocket | Header line. Connection: close | 2018-08-15 05:30:24
BitMEX WebSocket | Header line. | 2018-08-15 05:30:24
BitMEX WebSocket | Web socket state is now open. | 2018-08-15 05:30:24
BitMEX Trading Direct | Connected to data and trading server. | 2018-08-15 05:30:24
BitMEX WebSocket | Extension reserve bits set and not supported. | 2018-08-15 05:30:24
Connection to the external service has been lost. | 2018-08-15 05:30:24
BitMEX WebSocket socket (25) | Initiating close of socket by core. | 2018-08-15 05:30:24
BitMEX WebSocket | Network socket for WebSocket has been closed by remote side. | 2018-08-15 05:30:24
BitMEX WebSocket socket (25) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-15 05:30:24
BitMEX WebSocket socket (25) | Closed. | 2018-08-15 05:30:24
BitMEX WebSocket socket (0) | Ignored Send call based on current state. | 2018-08-15 05:30:24
BitMEX Trading Direct | Disconnected. | 2018-08-15 05:30:24
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:30:24
Intraday data recording state for symbol XBTUSD-BMEX is set to download 'Pending'. | 2018-08-15 05:30:24
HD Request # 5 | Downloading Intraday chart data for XBTUSD-BMEX to the file XBTUSD-BMEX.scid. Service: bitmex | 2018-08-15 05:30:24
HD Request # 5 | Download start date-time: 2018-08-15 05:30:20.000 | 2018-08-15 05:30:24
HD Request # 5 | Using server: ds3.sierracharts.com port 10150 | 2018-08-15 05:30:24
Socket (26) | Creating socket. | 2018-08-15 05:30:24
Socket (26) | Connecting to IP: 65.182.172.42. | 2018-08-15 05:30:24
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-08-15 05:30:27
BitMEX WebSocket | Connecting to WebSocket server. | 2018-08-15 05:30:27
BitMEX WebSocket socket (27) | Creating socket. Using TLS 1.2. | 2018-08-15 05:30:27
BitMEX WebSocket socket (27) | Connecting to IP: 34.249.155.157. | 2018-08-15 05:30:27
BitMEX WebSocket | Opening WebSocket. | 2018-08-15 05:30:28
BitMEX WebSocket | Sending WebSocket handshake. | 2018-08-15 05:30:28
HD Request # 5 | Setting DTC encoding to Binary VLS | 2018-08-15 05:30:28
HD Request # 5 | Sending historical data logon request message. | 2018-08-15 05:30:28
HD Request # 5 | Requesting Intraday data. Start date-time: 2018-08-15 05:30:20. Record interval: 1. Symbol: XBTUSD-BMEX | 2018-08-15 05:30:28
HD Request # 5 | Decompressing data. | 2018-08-15 05:30:28
HD Request # 5 | Receiving Intraday data for XBTUSD-BMEX starting at 2018-08-15 05:30:20 | 2018-08-15 05:30:28
HD Request # 5 | Timestamp of first Intraday data file record written: 2018-08-15 05:30:20 | 2018-08-15 05:30:28
Socket (26) | Initiating close of socket by core. | 2018-08-15 05:30:28
Socket (26) | Shutdown started. Waiting for graceful close. | 2018-08-15 05:30:28
HD Request # 5 | Historical data for XBTUSD-BMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-08-15 05:30:28
Historical data download thread signaled to stop. | 2018-08-15 05:30:28
HD Request # 5 | Received 3 records from 2018-08-15 05:30:20 to 2018-08-15 05:30:22 (2.0 seconds) and wrote 3 records for XBTUSD-BMEX | 2018-08-15 05:30:28
HD Request # 5 | Completion time: 4s | 2018-08-15 05:30:28
HD Request # 5 | Intraday data download complete for XBTUSD-BMEX. Unique request ID: 4 | 2018-08-15 05:30:28
Removed historical data download ID 4 | 2018-08-15 05:30:28
BitMEX WebSocket | Header line. HTTP/1.1 400 Bad Request | 2018-08-15 05:30:29
BitMEX WebSocket | WebSocket not connected. Handshake acknowledgment: HTTP/1.1 400 Bad Request | 2018-08-15 05:30:29
BitMEX Trading Direct | WebSocket closed. | 2018-08-15 05:30:29
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-15 05:30:29
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:30:29
BitMEX WebSocket socket (27) | Socket gracefully closed by remote side. | 2018-08-15 05:30:29
BitMEX WebSocket socket (27) | Received socket Close event. | 2018-08-15 05:30:29
BitMEX WebSocket | Header line. Server: awselb/2.0 | 2018-08-15 05:30:29
BitMEX WebSocket | Header line. Date: Wed, 15 Aug 2018 05:30:28 GMT | 2018-08-15 05:30:29
BitMEX WebSocket | Header line. Content-Type: text/html | 2018-08-15 05:30:29
BitMEX WebSocket | Header line. Content-Length: 138 | 2018-08-15 05:30:29
BitMEX WebSocket | Header line. Connection: close | 2018-08-15 05:30:29
BitMEX WebSocket | Header line. | 2018-08-15 05:30:29
BitMEX WebSocket | Web socket state is now open. | 2018-08-15 05:30:29
BitMEX Trading Direct | Connected to data and trading server. | 2018-08-15 05:30:29
BitMEX WebSocket | Extension reserve bits set and not supported. | 2018-08-15 05:30:29
Connection to the external service has been lost. | 2018-08-15 05:30:29
BitMEX WebSocket socket (27) | Initiating close of socket by core. | 2018-08-15 05:30:29
BitMEX WebSocket | Network socket for WebSocket has been closed by remote side. | 2018-08-15 05:30:29
BitMEX WebSocket socket (27) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-15 05:30:29
BitMEX WebSocket socket (27) | Closed. | 2018-08-15 05:30:29
BitMEX WebSocket socket (0) | Ignored Send call based on current state. | 2018-08-15 05:30:29
BitMEX Trading Direct | Disconnected. | 2018-08-15 05:30:29
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:30:29
Socket (26) | Socket gracefully closed by remote side. | 2018-08-15 05:30:29
Socket (26) | Closed. | 2018-08-15 05:30:29
Intraday data recording state for symbol XBTUSD-BMEX is set to download 'Pending'. | 2018-08-15 05:30:29
HD Request # 6 | Downloading Intraday chart data for XBTUSD-BMEX to the file XBTUSD-BMEX.scid. Service: bitmex | 2018-08-15 05:30:29
HD Request # 6 | Download start date-time: 2018-08-15 05:30:22.000 | 2018-08-15 05:30:29
HD Request # 6 | Using server: ds4.sierracharts.com port 10149 | 2018-08-15 05:30:29
Socket (28) | Creating socket. | 2018-08-15 05:30:29
Socket (28) | Connecting to IP: 192.81.56.146. | 2018-08-15 05:30:29
HD Request # 6 | Setting DTC encoding to Binary VLS | 2018-08-15 05:30:29
HD Request # 6 | Sending historical data logon request message. | 2018-08-15 05:30:29
HD Request # 6 | Requesting Intraday data. Start date-time: 2018-08-15 05:30:22. Record interval: 1. Symbol: XBTUSD-BMEX | 2018-08-15 05:30:29
HD Request # 6 | Decompressing data. | 2018-08-15 05:30:30
HD Request # 6 | Receiving Intraday data for XBTUSD-BMEX starting at 2018-08-15 05:30:22 | 2018-08-15 05:30:30
HD Request # 6 | Timestamp of first Intraday data file record written: 2018-08-15 05:30:22 | 2018-08-15 05:30:30
Socket (28) | Initiating close of socket by core. | 2018-08-15 05:30:30
Socket (28) | Shutdown started. Waiting for graceful close. | 2018-08-15 05:30:30
HD Request # 6 | Historical data for XBTUSD-BMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-08-15 05:30:30
Historical data download thread signaled to stop. | 2018-08-15 05:30:30
HD Request # 6 | Received 4 records from 2018-08-15 05:30:22 to 2018-08-15 05:30:27 (5.0 seconds) and wrote 4 records for XBTUSD-BMEX | 2018-08-15 05:30:30
HD Request # 6 | Completion time: 1s | 2018-08-15 05:30:30
HD Request # 6 | Intraday data download complete for XBTUSD-BMEX. Unique request ID: 5 | 2018-08-15 05:30:30
Removed historical data download ID 5 | 2018-08-15 05:30:30
Socket (28) | Socket gracefully closed by remote side. | 2018-08-15 05:30:30
Socket (28) | Closed. | 2018-08-15 05:30:30
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-08-15 05:30:32
BitMEX WebSocket | Connecting to WebSocket server. | 2018-08-15 05:30:32
BitMEX WebSocket socket (29) | Creating socket. Using TLS 1.2. | 2018-08-15 05:30:32
BitMEX WebSocket socket (29) | Connecting to IP: 34.249.155.157. | 2018-08-15 05:30:32
BitMEX WebSocket | Opening WebSocket. | 2018-08-15 05:30:32
BitMEX WebSocket | Sending WebSocket handshake. | 2018-08-15 05:30:32
BitMEX WebSocket socket (29) | Socket gracefully closed by remote side. | 2018-08-15 05:30:33
BitMEX WebSocket socket (29) | Received socket Close event. | 2018-08-15 05:30:33
BitMEX WebSocket | Header line. HTTP/1.1 400 Bad Request | 2018-08-15 05:30:33
BitMEX WebSocket | WebSocket not connected. Handshake acknowledgment: HTTP/1.1 400 Bad Request | 2018-08-15 05:30:33
BitMEX Trading Direct | WebSocket closed. | 2018-08-15 05:30:33
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-15 05:30:33
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:30:33
BitMEX WebSocket | Header line. Server: awselb/2.0 | 2018-08-15 05:30:33
BitMEX WebSocket | Header line. Date: Wed, 15 Aug 2018 05:30:32 GMT | 2018-08-15 05:30:33
BitMEX WebSocket | Header line. Content-Type: text/html | 2018-08-15 05:30:33
BitMEX WebSocket | Header line. Content-Length: 138 | 2018-08-15 05:30:33
BitMEX WebSocket | Header line. Connection: close | 2018-08-15 05:30:33
BitMEX WebSocket | Header line. | 2018-08-15 05:30:33
BitMEX WebSocket | Web socket state is now open. | 2018-08-15 05:30:33
BitMEX Trading Direct | Connected to data and trading server. | 2018-08-15 05:30:33
BitMEX WebSocket | Extension reserve bits set and not supported. | 2018-08-15 05:30:33
Connection to the external service has been lost. | 2018-08-15 05:30:33
BitMEX WebSocket socket (29) | Initiating close of socket by core. | 2018-08-15 05:30:33
BitMEX WebSocket | Network socket for WebSocket has been closed by remote side. | 2018-08-15 05:30:33
BitMEX WebSocket socket (29) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-15 05:30:33
BitMEX WebSocket socket (29) | Closed. | 2018-08-15 05:30:33
BitMEX WebSocket socket (0) | Ignored Send call based on current state. | 2018-08-15 05:30:33
BitMEX Trading Direct | Disconnected. | 2018-08-15 05:30:33
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:30:33
Intraday data recording state for symbol XBTUSD-BMEX is set to download 'Pending'. | 2018-08-15 05:30:33
HD Request # 7 | Downloading Intraday chart data for XBTUSD-BMEX to the file XBTUSD-BMEX.scid. Service: bitmex | 2018-08-15 05:30:33
HD Request # 7 | Download start date-time: 2018-08-15 05:30:27.000 | 2018-08-15 05:30:33
HD Request # 7 | Using server: ds3.sierracharts.com port 10150 | 2018-08-15 05:30:33
Socket (30) | Creating socket. | 2018-08-15 05:30:33
Socket (30) | Connecting to IP: 65.182.172.42. | 2018-08-15 05:30:33
HD Request # 7 | Setting DTC encoding to Binary VLS | 2018-08-15 05:30:34
HD Request # 7 | Sending historical data logon request message. | 2018-08-15 05:30:34
HD Request # 7 | Requesting Intraday data. Start date-time: 2018-08-15 05:30:27. Record interval: 1. Symbol: XBTUSD-BMEX | 2018-08-15 05:30:34
HD Request # 7 | Decompressing data. | 2018-08-15 05:30:34
HD Request # 7 | Receiving Intraday data for XBTUSD-BMEX starting at 2018-08-15 05:30:27 | 2018-08-15 05:30:34
HD Request # 7 | Timestamp of first Intraday data file record written: 2018-08-15 05:30:27 | 2018-08-15 05:30:34
Socket (30) | Initiating close of socket by core. | 2018-08-15 05:30:34
Socket (30) | Shutdown started. Waiting for graceful close. | 2018-08-15 05:30:34
HD Request # 7 | Historical data for XBTUSD-BMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-08-15 05:30:34
Historical data download thread signaled to stop. | 2018-08-15 05:30:34
HD Request # 7 | Received 5 records from 2018-08-15 05:30:27 to 2018-08-15 05:30:32 (5.0 seconds) and wrote 5 records for XBTUSD-BMEX | 2018-08-15 05:30:34
HD Request # 7 | Completion time: 1s | 2018-08-15 05:30:34
HD Request # 7 | Intraday data download complete for XBTUSD-BMEX. Unique request ID: 6 | 2018-08-15 05:30:34
Removed historical data download ID 6 | 2018-08-15 05:30:34
Socket (30) | Socket gracefully closed by remote side. | 2018-08-15 05:30:34
Socket (30) | Closed. | 2018-08-15 05:30:34
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-08-15 05:30:36
BitMEX WebSocket | Connecting to WebSocket server. | 2018-08-15 05:30:36
BitMEX WebSocket socket (31) | Creating socket. Using TLS 1.2. | 2018-08-15 05:30:36
BitMEX WebSocket socket (31) | Connecting to IP: 34.249.155.157. | 2018-08-15 05:30:36
BitMEX WebSocket | Opening WebSocket. | 2018-08-15 05:30:36
BitMEX WebSocket | Sending WebSocket handshake. | 2018-08-15 05:30:36
BitMEX WebSocket socket (31) | Received socket Close event. | 2018-08-15 05:30:37
BitMEX WebSocket socket (31) | Socket gracefully closed by remote side. | 2018-08-15 05:30:37
BitMEX WebSocket | Header line. HTTP/1.1 400 Bad Request | 2018-08-15 05:30:37
BitMEX WebSocket | WebSocket not connected. Handshake acknowledgment: HTTP/1.1 400 Bad Request | 2018-08-15 05:30:37
BitMEX Trading Direct | WebSocket closed. | 2018-08-15 05:30:37
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-15 05:30:37
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:30:37
BitMEX WebSocket | Header line. Server: awselb/2.0 | 2018-08-15 05:30:37
BitMEX WebSocket | Header line. Date: Wed, 15 Aug 2018 05:30:36 GMT | 2018-08-15 05:30:37
BitMEX WebSocket | Header line. Content-Type: text/html | 2018-08-15 05:30:37
BitMEX WebSocket | Header line. Content-Length: 138 | 2018-08-15 05:30:37
BitMEX WebSocket | Header line. Connection: close | 2018-08-15 05:30:37
BitMEX WebSocket | Header line. | 2018-08-15 05:30:37
BitMEX WebSocket | Web socket state is now open. | 2018-08-15 05:30:37
BitMEX Trading Direct | Connected to data and trading server. | 2018-08-15 05:30:37
BitMEX WebSocket | Extension reserve bits set and not supported. | 2018-08-15 05:30:37
Connection to the external service has been lost. | 2018-08-15 05:30:37
BitMEX WebSocket socket (31) | Initiating close of socket by core. | 2018-08-15 05:30:37
BitMEX WebSocket | Network socket for WebSocket has been closed by remote side. | 2018-08-15 05:30:37
BitMEX WebSocket socket (31) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-15 05:30:37
BitMEX WebSocket socket (31) | Closed. | 2018-08-15 05:30:37
BitMEX WebSocket socket (0) | Ignored Send call based on current state. | 2018-08-15 05:30:37
BitMEX Trading Direct | Disconnected. | 2018-08-15 05:30:37
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:30:37
Intraday data recording state for symbol XBTUSD-BMEX is set to download 'Pending'. | 2018-08-15 05:30:37
HD Request # 8 | Downloading Intraday chart data for XBTUSD-BMEX to the file XBTUSD-BMEX.scid. Service: bitmex | 2018-08-15 05:30:37
HD Request # 8 | Download start date-time: 2018-08-15 05:30:32.000 | 2018-08-15 05:30:37
HD Request # 8 | Using server: ds4.sierracharts.com port 10149 | 2018-08-15 05:30:37
Socket (32) | Creating socket. | 2018-08-15 05:30:37
Socket (32) | Connecting to IP: 192.81.56.146. | 2018-08-15 05:30:37
HD Request # 8 | Setting DTC encoding to Binary VLS | 2018-08-15 05:30:38
HD Request # 8 | Sending historical data logon request message. | 2018-08-15 05:30:38
HD Request # 8 | Requesting Intraday data. Start date-time: 2018-08-15 05:30:32. Record interval: 1. Symbol: XBTUSD-BMEX | 2018-08-15 05:30:38
HD Request # 8 | Decompressing data. | 2018-08-15 05:30:38
HD Request # 8 | Receiving Intraday data for XBTUSD-BMEX starting at 2018-08-15 05:30:32 | 2018-08-15 05:30:38
HD Request # 8 | Timestamp of first Intraday data file record written: 2018-08-15 05:30:32 | 2018-08-15 05:30:38
Socket (32) | Initiating close of socket by core. | 2018-08-15 05:30:38
Socket (32) | Shutdown started. Waiting for graceful close. | 2018-08-15 05:30:38
HD Request # 8 | Historical data for XBTUSD-BMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-08-15 05:30:38
Historical data download thread signaled to stop. | 2018-08-15 05:30:38
HD Request # 8 | Received 4 records from 2018-08-15 05:30:32 to 2018-08-15 05:30:36 (4.0 seconds) and wrote 4 records for XBTUSD-BMEX | 2018-08-15 05:30:38
HD Request # 8 | Completion time: 0s | 2018-08-15 05:30:38
HD Request # 8 | Intraday data download complete for XBTUSD-BMEX. Unique request ID: 7 | 2018-08-15 05:30:38
Removed historical data download ID 7 | 2018-08-15 05:30:38
Socket (32) | Socket gracefully closed by remote side. | 2018-08-15 05:30:38
Socket (32) | Closed. | 2018-08-15 05:30:38
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-08-15 05:30:40
BitMEX WebSocket | Connecting to WebSocket server. | 2018-08-15 05:30:40
BitMEX WebSocket socket (33) | Creating socket. Using TLS 1.2. | 2018-08-15 05:30:40
BitMEX WebSocket socket (33) | Connecting to IP: 34.249.155.157. | 2018-08-15 05:30:40
BitMEX WebSocket | Opening WebSocket. | 2018-08-15 05:30:40
BitMEX WebSocket | Sending WebSocket handshake. | 2018-08-15 05:30:40
BitMEX WebSocket socket (33) | Socket gracefully closed by remote side. | 2018-08-15 05:30:41
BitMEX WebSocket socket (33) | Received socket Close event. | 2018-08-15 05:30:41
BitMEX WebSocket | Header line. HTTP/1.1 400 Bad Request | 2018-08-15 05:30:41
BitMEX WebSocket | WebSocket not connected. Handshake acknowledgment: HTTP/1.1 400 Bad Request | 2018-08-15 05:30:41
BitMEX Trading Direct | WebSocket closed. | 2018-08-15 05:30:41
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-15 05:30:41
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:30:41
BitMEX WebSocket | Header line. Server: awselb/2.0 | 2018-08-15 05:30:41
BitMEX WebSocket | Header line. Date: Wed, 15 Aug 2018 05:30:41 GMT | 2018-08-15 05:30:41
BitMEX WebSocket | Header line. Content-Type: text/html | 2018-08-15 05:30:41
BitMEX WebSocket | Header line. Content-Length: 138 | 2018-08-15 05:30:41
BitMEX WebSocket | Header line. Connection: close | 2018-08-15 05:30:41
BitMEX WebSocket | Header line. | 2018-08-15 05:30:41
BitMEX WebSocket | Web socket state is now open. | 2018-08-15 05:30:41
BitMEX Trading Direct | Connected to data and trading server. | 2018-08-15 05:30:41
BitMEX WebSocket | Extension reserve bits set and not supported. | 2018-08-15 05:30:41
Connection to the external service has been lost. | 2018-08-15 05:30:41
BitMEX WebSocket socket (33) | Initiating close of socket by core. | 2018-08-15 05:30:41
BitMEX WebSocket | Network socket for WebSocket has been closed by remote side. | 2018-08-15 05:30:41
BitMEX WebSocket socket (33) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-15 05:30:41
BitMEX WebSocket socket (33) | Closed. | 2018-08-15 05:30:41
BitMEX WebSocket socket (0) | Ignored Send call based on current state. | 2018-08-15 05:30:41
BitMEX Trading Direct | Disconnected. | 2018-08-15 05:30:41
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:30:41
Intraday data recording state for symbol XBTUSD-BMEX is set to download 'Pending'. | 2018-08-15 05:30:41
HD Request # 9 | Downloading Intraday chart data for XBTUSD-BMEX to the file XBTUSD-BMEX.scid. Service: bitmex | 2018-08-15 05:30:41
HD Request # 9 | Download start date-time: 2018-08-15 05:30:36.000 | 2018-08-15 05:30:42
HD Request # 9 | Using server: ds3.sierracharts.com port 10150 | 2018-08-15 05:30:42
Socket (34) | Creating socket. | 2018-08-15 05:30:42
Socket (34) | Connecting to IP: 65.182.172.42. | 2018-08-15 05:30:42
HD Request # 9 | Setting DTC encoding to Binary VLS | 2018-08-15 05:30:42
HD Request # 9 | Sending historical data logon request message. | 2018-08-15 05:30:42
HD Request # 9 | Requesting Intraday data. Start date-time: 2018-08-15 05:30:36. Record interval: 1. Symbol: XBTUSD-BMEX | 2018-08-15 05:30:42
HD Request # 9 | Decompressing data. | 2018-08-15 05:30:43
HD Request # 9 | Receiving Intraday data for XBTUSD-BMEX starting at 2018-08-15 05:30:36 | 2018-08-15 05:30:43
HD Request # 9 | Timestamp of first Intraday data file record written: 2018-08-15 05:30:36 | 2018-08-15 05:30:43
Socket (34) | Initiating close of socket by core. | 2018-08-15 05:30:43
Socket (34) | Shutdown started. Waiting for graceful close. | 2018-08-15 05:30:43
HD Request # 9 | Historical data for XBTUSD-BMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-08-15 05:30:43
Historical data download thread signaled to stop. | 2018-08-15 05:30:43
HD Request # 9 | Received 4 records from 2018-08-15 05:30:36 to 2018-08-15 05:30:39 (3.0 seconds) and wrote 4 records for XBTUSD-BMEX | 2018-08-15 05:30:43
HD Request # 9 | Completion time: 1s | 2018-08-15 05:30:43
HD Request # 9 | Intraday data download complete for XBTUSD-BMEX. Unique request ID: 8 | 2018-08-15 05:30:43
Removed historical data download ID 8 | 2018-08-15 05:30:43
Socket (34) | Socket gracefully closed by remote side. | 2018-08-15 05:30:43
Socket (34) | Closed. | 2018-08-15 05:30:43
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-08-15 05:30:44
BitMEX WebSocket | Connecting to WebSocket server. | 2018-08-15 05:30:44
BitMEX WebSocket socket (35) | Creating socket. Using TLS 1.2. | 2018-08-15 05:30:44
BitMEX WebSocket socket (35) | Connecting to IP: 34.249.155.157. | 2018-08-15 05:30:44
BitMEX WebSocket | Opening WebSocket. | 2018-08-15 05:30:45
BitMEX WebSocket | Sending WebSocket handshake. | 2018-08-15 05:30:45
BitMEX WebSocket socket (35) | Socket gracefully closed by remote side. | 2018-08-15 05:30:46
BitMEX WebSocket | Header line. HTTP/1.1 400 Bad Request | 2018-08-15 05:30:46
BitMEX WebSocket socket (35) | Received socket Close event. | 2018-08-15 05:30:46
BitMEX WebSocket | WebSocket not connected. Handshake acknowledgment: HTTP/1.1 400 Bad Request | 2018-08-15 05:30:46
BitMEX Trading Direct | WebSocket closed. | 2018-08-15 05:30:46
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-15 05:30:46
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:30:46
BitMEX WebSocket | Header line. Server: awselb/2.0 | 2018-08-15 05:30:46
BitMEX WebSocket | Header line. Date: Wed, 15 Aug 2018 05:30:45 GMT | 2018-08-15 05:30:46
BitMEX WebSocket | Header line. Content-Type: text/html | 2018-08-15 05:30:46
BitMEX WebSocket | Header line. Content-Length: 138 | 2018-08-15 05:30:46
BitMEX WebSocket | Header line. Connection: close | 2018-08-15 05:30:46
BitMEX WebSocket | Header line. | 2018-08-15 05:30:46
BitMEX WebSocket | Web socket state is now open. | 2018-08-15 05:30:46
BitMEX Trading Direct | Connected to data and trading server. | 2018-08-15 05:30:46
BitMEX WebSocket | Extension reserve bits set and not supported. | 2018-08-15 05:30:46
Connection to the external service has been lost. | 2018-08-15 05:30:46
BitMEX WebSocket socket (35) | Initiating close of socket by core. | 2018-08-15 05:30:46
BitMEX WebSocket | Network socket for WebSocket has been closed by remote side. | 2018-08-15 05:30:46
BitMEX WebSocket socket (35) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-15 05:30:46
BitMEX WebSocket socket (35) | Closed. | 2018-08-15 05:30:46
Intraday data recording state for symbol XBTUSD-BMEX is set to download 'Pending'. | 2018-08-15 05:30:46
HD Request # 10 | Downloading Intraday chart data for XBTUSD-BMEX to the file XBTUSD-BMEX.scid. Service: bitmex | 2018-08-15 05:30:46
HD Request # 10 | Download start date-time: 2018-08-15 05:30:39.000 | 2018-08-15 05:30:46
HD Request # 10 | Using server: ds4.sierracharts.com port 10149 | 2018-08-15 05:30:46
Socket (36) | Creating socket. | 2018-08-15 05:30:46
Socket (36) | Connecting to IP: 192.81.56.146. | 2018-08-15 05:30:46
BitMEX WebSocket socket (0) | Ignored Send call based on current state. | 2018-08-15 05:30:46
BitMEX Trading Direct | Disconnected. | 2018-08-15 05:30:46
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:30:46
HD Request # 10 | Setting DTC encoding to Binary VLS | 2018-08-15 05:30:46
HD Request # 10 | Sending historical data logon request message. | 2018-08-15 05:30:46
HD Request # 10 | Requesting Intraday data. Start date-time: 2018-08-15 05:30:39. Record interval: 1. Symbol: XBTUSD-BMEX | 2018-08-15 05:30:46
HD Request # 10 | Decompressing data. | 2018-08-15 05:30:46
HD Request # 10 | Receiving Intraday data for XBTUSD-BMEX starting at 2018-08-15 05:30:39 | 2018-08-15 05:30:46
HD Request # 10 | Timestamp of first Intraday data file record written: 2018-08-15 05:30:39 | 2018-08-15 05:30:46
Socket (36) | Initiating close of socket by core. | 2018-08-15 05:30:46
Socket (36) | Shutdown started. Waiting for graceful close. | 2018-08-15 05:30:46
HD Request # 10 | Historical data for XBTUSD-BMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-08-15 05:30:46
Historical data download thread signaled to stop. | 2018-08-15 05:30:46
HD Request # 10 | Received 4 records from 2018-08-15 05:30:39 to 2018-08-15 05:30:43 (4.0 seconds) and wrote 4 records for XBTUSD-BMEX | 2018-08-15 05:30:46
HD Request # 10 | Completion time: 0s | 2018-08-15 05:30:46
HD Request # 10 | Intraday data download complete for XBTUSD-BMEX. Unique request ID: 9 | 2018-08-15 05:30:46
Removed historical data download ID 9 | 2018-08-15 05:30:46
Socket (36) | Socket gracefully closed by remote side. | 2018-08-15 05:30:47
Socket (36) | Closed. | 2018-08-15 05:30:47
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-08-15 05:30:49
BitMEX WebSocket | Connecting to WebSocket server. | 2018-08-15 05:30:49
BitMEX WebSocket socket (37) | Creating socket. Using TLS 1.2. | 2018-08-15 05:30:49
BitMEX WebSocket socket (37) | Connecting to IP: 34.249.155.157. | 2018-08-15 05:30:49
BitMEX WebSocket | Opening WebSocket. | 2018-08-15 05:30:49
BitMEX WebSocket | Sending WebSocket handshake. | 2018-08-15 05:30:49
BitMEX WebSocket | Header line. HTTP/1.1 400 Bad Request | 2018-08-15 05:30:50
BitMEX WebSocket | WebSocket not connected. Handshake acknowledgment: HTTP/1.1 400 Bad Request | 2018-08-15 05:30:50
BitMEX Trading Direct | WebSocket closed. | 2018-08-15 05:30:50
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-15 05:30:50
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:30:50
BitMEX WebSocket socket (37) | Socket gracefully closed by remote side. | 2018-08-15 05:30:50
BitMEX WebSocket socket (37) | Received socket Close event. | 2018-08-15 05:30:50
BitMEX WebSocket | Header line. Server: awselb/2.0 | 2018-08-15 05:30:50
BitMEX WebSocket | Header line. Date: Wed, 15 Aug 2018 05:30:49 GMT | 2018-08-15 05:30:50
BitMEX WebSocket | Header line. Content-Type: text/html | 2018-08-15 05:30:50
BitMEX WebSocket | Header line. Content-Length: 138 | 2018-08-15 05:30:50
BitMEX WebSocket | Header line. Connection: close | 2018-08-15 05:30:50
BitMEX WebSocket | Header line. | 2018-08-15 05:30:50
BitMEX WebSocket | Web socket state is now open. | 2018-08-15 05:30:50
BitMEX Trading Direct | Connected to data and trading server. | 2018-08-15 05:30:50
BitMEX WebSocket | Extension reserve bits set and not supported. | 2018-08-15 05:30:50
Connection to the external service has been lost. | 2018-08-15 05:30:50
BitMEX WebSocket socket (37) | Initiating close of socket by core. | 2018-08-15 05:30:50
BitMEX WebSocket | Network socket for WebSocket has been closed by remote side. | 2018-08-15 05:30:50
BitMEX WebSocket socket (37) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-15 05:30:50
BitMEX WebSocket socket (37) | Closed. | 2018-08-15 05:30:50
BitMEX WebSocket socket (0) | Ignored Send call based on current state. | 2018-08-15 05:30:50
BitMEX Trading Direct | Disconnected. | 2018-08-15 05:30:50
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:30:50
Intraday data recording state for symbol XBTUSD-BMEX is set to download 'Pending'. | 2018-08-15 05:30:50
HD Request # 11 | Downloading Intraday chart data for XBTUSD-BMEX to the file XBTUSD-BMEX.scid. Service: bitmex | 2018-08-15 05:30:50
HD Request # 11 | Download start date-time: 2018-08-15 05:30:43.000 | 2018-08-15 05:30:50
HD Request # 11 | Using server: ds3.sierracharts.com port 10150 | 2018-08-15 05:30:50
Socket (38) | Creating socket. | 2018-08-15 05:30:50
Socket (38) | Connecting to IP: 65.182.172.42. | 2018-08-15 05:30:50
HD Request # 11 | Setting DTC encoding to Binary VLS | 2018-08-15 05:30:50
HD Request # 11 | Sending historical data logon request message. | 2018-08-15 05:30:50
HD Request # 11 | Requesting Intraday data. Start date-time: 2018-08-15 05:30:43. Record interval: 1. Symbol: XBTUSD-BMEX | 2018-08-15 05:30:51
HD Request # 11 | Decompressing data. | 2018-08-15 05:30:51
HD Request # 11 | Receiving Intraday data for XBTUSD-BMEX starting at 2018-08-15 05:30:43 | 2018-08-15 05:30:51
HD Request # 11 | Timestamp of first Intraday data file record written: 2018-08-15 05:30:43 | 2018-08-15 05:30:51
Socket (38) | Initiating close of socket by core. | 2018-08-15 05:30:51
HD Request # 11 | Historical data for XBTUSD-BMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-08-15 05:30:51
Socket (38) | Shutdown started. Waiting for graceful close. | 2018-08-15 05:30:51
Historical data download thread signaled to stop. | 2018-08-15 05:30:51
HD Request # 11 | Received 4 records from 2018-08-15 05:30:43 to 2018-08-15 05:30:48 (5.0 seconds) and wrote 4 records for XBTUSD-BMEX | 2018-08-15 05:30:51
HD Request # 11 | Completion time: 1s | 2018-08-15 05:30:51
HD Request # 11 | Intraday data download complete for XBTUSD-BMEX. Unique request ID: 10 | 2018-08-15 05:30:51
Removed historical data download ID 10 | 2018-08-15 05:30:51
Socket (38) | Socket gracefully closed by remote side. | 2018-08-15 05:30:51
Socket (38) | Closed. | 2018-08-15 05:30:51
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-08-15 05:30:53
BitMEX WebSocket | Connecting to WebSocket server. | 2018-08-15 05:30:53
BitMEX WebSocket socket (39) | Creating socket. Using TLS 1.2. | 2018-08-15 05:30:53
BitMEX WebSocket socket (39) | Connecting to IP: 34.249.155.157. | 2018-08-15 05:30:53
BitMEX WebSocket | Opening WebSocket. | 2018-08-15 05:30:53
BitMEX WebSocket | Sending WebSocket handshake. | 2018-08-15 05:30:53
BitMEX WebSocket socket (39) | Socket gracefully closed by remote side. | 2018-08-15 05:30:54
BitMEX WebSocket | Header line. HTTP/1.1 400 Bad Request | 2018-08-15 05:30:54
BitMEX WebSocket | WebSocket not connected. Handshake acknowledgment: HTTP/1.1 400 Bad Request | 2018-08-15 05:30:54
BitMEX Trading Direct | WebSocket closed. | 2018-08-15 05:30:54
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-15 05:30:54
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:30:54
BitMEX WebSocket socket (39) | Received socket Close event. | 2018-08-15 05:30:54
BitMEX WebSocket | Header line. Server: awselb/2.0 | 2018-08-15 05:30:54
BitMEX WebSocket | Header line. Date: Wed, 15 Aug 2018 05:30:53 GMT | 2018-08-15 05:30:54
BitMEX WebSocket | Header line. Content-Type: text/html | 2018-08-15 05:30:54
BitMEX WebSocket | Header line. Content-Length: 138 | 2018-08-15 05:30:54
BitMEX WebSocket | Header line. Connection: close | 2018-08-15 05:30:54
BitMEX WebSocket | Header line. | 2018-08-15 05:30:54
BitMEX WebSocket | Web socket state is now open. | 2018-08-15 05:30:54
BitMEX Trading Direct | Connected to data and trading server. | 2018-08-15 05:30:54
BitMEX WebSocket | Extension reserve bits set and not supported. | 2018-08-15 05:30:54
Connection to the external service has been lost. | 2018-08-15 05:30:54
BitMEX WebSocket socket (39) | Initiating close of socket by core. | 2018-08-15 05:30:54
BitMEX WebSocket | Network socket for WebSocket has been closed by remote side. | 2018-08-15 05:30:54
BitMEX WebSocket socket (39) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-15 05:30:54
BitMEX WebSocket socket (39) | Closed. | 2018-08-15 05:30:54
BitMEX WebSocket socket (0) | Ignored Send call based on current state. | 2018-08-15 05:30:54
BitMEX Trading Direct | Disconnected. | 2018-08-15 05:30:54
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:30:54
Intraday data recording state for symbol XBTUSD-BMEX is set to download 'Pending'. | 2018-08-15 05:30:54
HD Request # 12 | Downloading Intraday chart data for XBTUSD-BMEX to the file XBTUSD-BMEX.scid. Service: bitmex | 2018-08-15 05:30:54
HD Request # 12 | Download start date-time: 2018-08-15 05:30:48.000 | 2018-08-15 05:30:54
HD Request # 12 | Using server: ds4.sierracharts.com port 10149 | 2018-08-15 05:30:54
Socket (40) | Creating socket. | 2018-08-15 05:30:54
Socket (40) | Connecting to IP: 192.81.56.146. | 2018-08-15 05:30:54
HD Request # 12 | Setting DTC encoding to Binary VLS | 2018-08-15 05:30:55
HD Request # 12 | Sending historical data logon request message. | 2018-08-15 05:30:55
HD Request # 12 | Requesting Intraday data. Start date-time: 2018-08-15 05:30:48. Record interval: 1. Symbol: XBTUSD-BMEX | 2018-08-15 05:30:55
HD Request # 12 | Decompressing data. | 2018-08-15 05:30:55
HD Request # 12 | Receiving Intraday data for XBTUSD-BMEX starting at 2018-08-15 05:30:48 | 2018-08-15 05:30:55
HD Request # 12 | Timestamp of first Intraday data file record written: 2018-08-15 05:30:48 | 2018-08-15 05:30:55
Socket (40) | Initiating close of socket by core. | 2018-08-15 05:30:55
HD Request # 12 | Historical data for XBTUSD-BMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-08-15 05:30:55
Socket (40) | Shutdown started. Waiting for graceful close. | 2018-08-15 05:30:55
Historical data download thread signaled to stop. | 2018-08-15 05:30:55
HD Request # 12 | Received 4 records from 2018-08-15 05:30:48 to 2018-08-15 05:30:52 (4.0 seconds) and wrote 4 records for XBTUSD-BMEX | 2018-08-15 05:30:55
HD Request # 12 | Completion time: 1s | 2018-08-15 05:30:55
HD Request # 12 | Intraday data download complete for XBTUSD-BMEX. Unique request ID: 11 | 2018-08-15 05:30:55
Removed historical data download ID 11 | 2018-08-15 05:30:55
Socket (40) | Socket gracefully closed by remote side. | 2018-08-15 05:30:55
Socket (40) | Closed. | 2018-08-15 05:30:55
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-08-15 05:30:57
BitMEX WebSocket | Connecting to WebSocket server. | 2018-08-15 05:30:57
BitMEX WebSocket socket (41) | Creating socket. Using TLS 1.2. | 2018-08-15 05:30:57
BitMEX WebSocket socket (41) | Connecting to IP: 34.249.155.157. | 2018-08-15 05:30:57
BitMEX WebSocket | Opening WebSocket. | 2018-08-15 05:30:57
BitMEX WebSocket | Sending WebSocket handshake. | 2018-08-15 05:30:57
BitMEX WebSocket socket (41) | Socket gracefully closed by remote side. | 2018-08-15 05:30:58
BitMEX WebSocket socket (41) | Received socket Close event. | 2018-08-15 05:30:58
BitMEX WebSocket | Header line. HTTP/1.1 400 Bad Request | 2018-08-15 05:30:58
BitMEX WebSocket | WebSocket not connected. Handshake acknowledgment: HTTP/1.1 400 Bad Request | 2018-08-15 05:30:58
BitMEX Trading Direct | WebSocket closed. | 2018-08-15 05:30:58
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-15 05:30:58
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:30:58
BitMEX WebSocket | Header line. Server: awselb/2.0 | 2018-08-15 05:30:58
BitMEX WebSocket | Header line. Date: Wed, 15 Aug 2018 05:30:58 GMT | 2018-08-15 05:30:58
BitMEX WebSocket | Header line. Content-Type: text/html | 2018-08-15 05:30:58
BitMEX WebSocket | Header line. Content-Length: 138 | 2018-08-15 05:30:58
BitMEX WebSocket | Header line. Connection: close | 2018-08-15 05:30:58
BitMEX WebSocket | Header line. | 2018-08-15 05:30:58
BitMEX WebSocket | Web socket state is now open. | 2018-08-15 05:30:58
BitMEX Trading Direct | Connected to data and trading server. | 2018-08-15 05:30:58
BitMEX WebSocket | Extension reserve bits set and not supported. | 2018-08-15 05:30:58
Connection to the external service has been lost. | 2018-08-15 05:30:58
BitMEX WebSocket socket (41) | Initiating close of socket by core. | 2018-08-15 05:30:58
BitMEX WebSocket | Network socket for WebSocket has been closed by remote side. | 2018-08-15 05:30:58
BitMEX WebSocket socket (41) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-15 05:30:58
BitMEX WebSocket socket (41) | Closed. | 2018-08-15 05:30:58
BitMEX WebSocket socket (0) | Ignored Send call based on current state. | 2018-08-15 05:30:58
BitMEX Trading Direct | Disconnected. | 2018-08-15 05:30:58
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:30:58
Intraday data recording state for symbol XBTUSD-BMEX is set to download 'Pending'. | 2018-08-15 05:30:58
HD Request # 13 | Downloading Intraday chart data for XBTUSD-BMEX to the file XBTUSD-BMEX.scid. Service: bitmex | 2018-08-15 05:30:58
HD Request # 13 | Download start date-time: 2018-08-15 05:30:52.000 | 2018-08-15 05:30:58
HD Request # 13 | Using server: ds3.sierracharts.com port 10150 | 2018-08-15 05:30:58
Socket (42) | Creating socket. | 2018-08-15 05:30:58
Socket (42) | Connecting to IP: 65.182.172.42. | 2018-08-15 05:30:58
HD Request # 13 | Setting DTC encoding to Binary VLS | 2018-08-15 05:30:59
HD Request # 13 | Sending historical data logon request message. | 2018-08-15 05:30:59
HD Request # 13 | Requesting Intraday data. Start date-time: 2018-08-15 05:30:52. Record interval: 1. Symbol: XBTUSD-BMEX | 2018-08-15 05:31:00
File >> Disconnect selected. | 2018-08-15 05:31:00
BitMEX Trading Direct | Disconnected. | 2018-08-15 05:31:00
HD Request # 13 | Decompressing data. | 2018-08-15 05:31:00
HD Request # 13 | Receiving Intraday data for XBTUSD-BMEX starting at 2018-08-15 05:30:52 | 2018-08-15 05:31:00
HD Request # 13 | Timestamp of first Intraday data file record written: 2018-08-15 05:30:52 | 2018-08-15 05:31:00
Socket (42) | Initiating close of socket by core. | 2018-08-15 05:31:00
HD Request # 13 | Historical data for XBTUSD-BMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-08-15 05:31:00
Socket (42) | Shutdown started. Waiting for graceful close. | 2018-08-15 05:31:00
Historical data download thread signaled to stop. | 2018-08-15 05:31:00
HD Request # 13 | Received 3 records from 2018-08-15 05:30:52 to 2018-08-15 05:30:54 (2.0 seconds) and wrote 3 records for XBTUSD-BMEX | 2018-08-15 05:31:00
HD Request # 13 | Completion time: 2s | 2018-08-15 05:31:00
HD Request # 13 | Intraday data download complete for XBTUSD-BMEX. Unique request ID: 12 | 2018-08-15 05:31:00
Removed historical data download ID 12 | 2018-08-15 05:31:00
Socket (42) | Socket gracefully closed by remote side. | 2018-08-15 05:31:00
Socket (42) | Closed. | 2018-08-15 05:31:00
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-08-15 05:35:15
BitMEX WebSocket | Connecting to WebSocket server. | 2018-08-15 05:35:15
BitMEX WebSocket socket (48) | Creating socket. Using TLS 1.2. | 2018-08-15 05:35:15
BitMEX WebSocket socket (48) | Connecting to IP: 54.194.47.252. | 2018-08-15 05:35:15
BitMEX WebSocket | Opening WebSocket. | 2018-08-15 05:35:15
BitMEX WebSocket | Sending WebSocket handshake. | 2018-08-15 05:35:15
BitMEX WebSocket | Header line. HTTP/1.1 400 Bad Request | 2018-08-15 05:35:16
BitMEX WebSocket | WebSocket not connected. Handshake acknowledgment: HTTP/1.1 400 Bad Request | 2018-08-15 05:35:16
BitMEX WebSocket socket (48) | Socket gracefully closed by remote side. | 2018-08-15 05:35:16
BitMEX Trading Direct | WebSocket closed. | 2018-08-15 05:35:16
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-15 05:35:16
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:35:16
BitMEX WebSocket socket (48) | Received socket Close event. | 2018-08-15 05:35:16
BitMEX WebSocket | Header line. Server: awselb/2.0 | 2018-08-15 05:35:16
BitMEX WebSocket | Header line. Date: Wed, 15 Aug 2018 05:35:16 GMT | 2018-08-15 05:35:16
BitMEX WebSocket | Header line. Content-Type: text/html | 2018-08-15 05:35:16
BitMEX WebSocket | Header line. Content-Length: 138 | 2018-08-15 05:35:16
BitMEX WebSocket | Header line. Connection: close | 2018-08-15 05:35:16
BitMEX WebSocket | Header line. | 2018-08-15 05:35:16
BitMEX WebSocket | Web socket state is now open. | 2018-08-15 05:35:16
BitMEX Trading Direct | Connected to data and trading server. | 2018-08-15 05:35:16
BitMEX WebSocket | Extension reserve bits set and not supported. | 2018-08-15 05:35:16
Connection to the external service has been lost. | 2018-08-15 05:35:16
BitMEX WebSocket socket (48) | Initiating close of socket by core. | 2018-08-15 05:35:16
BitMEX WebSocket | Network socket for WebSocket has been closed by remote side. | 2018-08-15 05:35:16
BitMEX WebSocket socket (48) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-15 05:35:16
BitMEX WebSocket socket (48) | Closed. | 2018-08-15 05:35:16
BitMEX WebSocket socket (0) | Ignored Send call based on current state. | 2018-08-15 05:35:16
BitMEX Trading Direct | Disconnected. | 2018-08-15 05:35:16
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:35:16
Intraday data recording state for symbol XBTUSD-BMEX is set to download 'Pending'. | 2018-08-15 05:35:16
HD Request # 14 | Downloading Intraday chart data for XBTUSD-BMEX to the file XBTUSD-BMEX.scid. Service: bitmex | 2018-08-15 05:35:16
HD Request # 14 | Download start date-time: 2018-08-15 05:30:54.000 | 2018-08-15 05:35:16
HD Request # 14 | Using server: ds4.sierracharts.com port 10149 | 2018-08-15 05:35:16
Socket (49) | Creating socket. | 2018-08-15 05:35:16
Socket (49) | Connecting to IP: 192.81.56.146. | 2018-08-15 05:35:16
HD Request # 14 | Setting DTC encoding to Binary VLS | 2018-08-15 05:35:17
HD Request # 14 | Sending historical data logon request message. | 2018-08-15 05:35:17
HD Request # 14 | Requesting Intraday data. Start date-time: 2018-08-15 05:30:54. Record interval: 1. Symbol: XBTUSD-BMEX | 2018-08-15 05:35:17
HD Request # 14 | Decompressing data. | 2018-08-15 05:35:17
HD Request # 14 | Receiving Intraday data for XBTUSD-BMEX starting at 2018-08-15 05:30:54 | 2018-08-15 05:35:17
HD Request # 14 | Timestamp of first Intraday data file record written: 2018-08-15 05:30:54 | 2018-08-15 05:35:17
Socket (49) | Initiating close of socket by core. | 2018-08-15 05:35:17
Socket (49) | Shutdown started. Waiting for graceful close. | 2018-08-15 05:35:17
HD Request # 14 | Historical data for XBTUSD-BMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-08-15 05:35:17
Historical data download thread signaled to stop. | 2018-08-15 05:35:17
HD Request # 14 | Received 189 records from 2018-08-15 05:30:54 to 2018-08-15 05:35:12 (4.3 minutes) and wrote 189 records for XBTUSD-BMEX | 2018-08-15 05:35:17
HD Request # 14 | Completion time: 0s | 2018-08-15 05:35:17
HD Request # 14 | Intraday data download complete for XBTUSD-BMEX. Unique request ID: 13 | 2018-08-15 05:35:17
Removed historical data download ID 13 | 2018-08-15 05:35:17
Socket (49) | Socket gracefully closed by remote side. | 2018-08-15 05:35:17
Socket (49) | Closed. | 2018-08-15 05:35:17
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-08-15 05:35:19
BitMEX WebSocket | Connecting to WebSocket server. | 2018-08-15 05:35:19
BitMEX WebSocket socket (50) | Creating socket. Using TLS 1.2. | 2018-08-15 05:35:19
BitMEX WebSocket socket (50) | Connecting to IP: 54.194.47.252. | 2018-08-15 05:35:19
BitMEX WebSocket | Opening WebSocket. | 2018-08-15 05:35:20
BitMEX WebSocket | Sending WebSocket handshake. | 2018-08-15 05:35:20
BitMEX WebSocket socket (50) | Received socket Close event. | 2018-08-15 05:35:20
BitMEX WebSocket socket (50) | Socket gracefully closed by remote side. | 2018-08-15 05:35:20
BitMEX WebSocket | Header line. HTTP/1.1 400 Bad Request | 2018-08-15 05:35:20
BitMEX WebSocket | WebSocket not connected. Handshake acknowledgment: HTTP/1.1 400 Bad Request | 2018-08-15 05:35:20
BitMEX Trading Direct | WebSocket closed. | 2018-08-15 05:35:20
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-15 05:35:20
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:35:20
BitMEX WebSocket | Header line. Server: awselb/2.0 | 2018-08-15 05:35:20
BitMEX WebSocket | Header line. Date: Wed, 15 Aug 2018 05:35:20 GMT | 2018-08-15 05:35:20
BitMEX WebSocket | Header line. Content-Type: text/html | 2018-08-15 05:35:20
BitMEX WebSocket | Header line. Content-Length: 138 | 2018-08-15 05:35:20
BitMEX WebSocket | Header line. Connection: close | 2018-08-15 05:35:20
BitMEX WebSocket | Header line. | 2018-08-15 05:35:20
BitMEX WebSocket | Web socket state is now open. | 2018-08-15 05:35:20
BitMEX Trading Direct | Connected to data and trading server. | 2018-08-15 05:35:20
BitMEX WebSocket | Extension reserve bits set and not supported. | 2018-08-15 05:35:20
Connection to the external service has been lost. | 2018-08-15 05:35:20
BitMEX WebSocket socket (50) | Initiating close of socket by core. | 2018-08-15 05:35:20
BitMEX WebSocket | Network socket for WebSocket has been closed by remote side. | 2018-08-15 05:35:20
BitMEX WebSocket socket (50) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-15 05:35:20
BitMEX WebSocket socket (50) | Closed. | 2018-08-15 05:35:20
BitMEX WebSocket socket (0) | Ignored Send call based on current state. | 2018-08-15 05:35:21
BitMEX Trading Direct | Disconnected. | 2018-08-15 05:35:21
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:35:21
Intraday data recording state for symbol XBTUSD-BMEX is set to download 'Pending'. | 2018-08-15 05:35:21
HD Request # 15 | Downloading Intraday chart data for XBTUSD-BMEX to the file XBTUSD-BMEX.scid. Service: bitmex | 2018-08-15 05:35:21
HD Request # 15 | Download start date-time: 2018-08-15 05:35:12.000 | 2018-08-15 05:35:21
HD Request # 15 | Using server: ds3.sierracharts.com port 10150 | 2018-08-15 05:35:21
Socket (51) | Creating socket. | 2018-08-15 05:35:21
Socket (51) | Connecting to IP: 65.182.172.42. | 2018-08-15 05:35:21
HD Request # 15 | Setting DTC encoding to Binary VLS | 2018-08-15 05:35:21
HD Request # 15 | Sending historical data logon request message. | 2018-08-15 05:35:21
HD Request # 15 | Requesting Intraday data. Start date-time: 2018-08-15 05:35:12. Record interval: 1. Symbol: XBTUSD-BMEX | 2018-08-15 05:35:21
HD Request # 15 | Decompressing data. | 2018-08-15 05:35:22
HD Request # 15 | Receiving Intraday data for XBTUSD-BMEX starting at 2018-08-15 05:35:12 | 2018-08-15 05:35:22
HD Request # 15 | Timestamp of first Intraday data file record written: 2018-08-15 05:35:12 | 2018-08-15 05:35:22
Socket (51) | Initiating close of socket by core. | 2018-08-15 05:35:22
HD Request # 15 | Historical data for XBTUSD-BMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-08-15 05:35:22
Socket (51) | Shutdown started. Waiting for graceful close. | 2018-08-15 05:35:22
Historical data download thread signaled to stop. | 2018-08-15 05:35:22
HD Request # 15 | Received 5 records from 2018-08-15 05:35:12 to 2018-08-15 05:35:17 (5.0 seconds) and wrote 5 records for XBTUSD-BMEX | 2018-08-15 05:35:22
HD Request # 15 | Completion time: 1s | 2018-08-15 05:35:22
HD Request # 15 | Intraday data download complete for XBTUSD-BMEX. Unique request ID: 14 | 2018-08-15 05:35:22
Removed historical data download ID 14 | 2018-08-15 05:35:22
Socket (51) | Socket gracefully closed by remote side. | 2018-08-15 05:35:22
Socket (51) | Closed. | 2018-08-15 05:35:22
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-08-15 05:35:24
BitMEX WebSocket | Connecting to WebSocket server. | 2018-08-15 05:35:24
BitMEX WebSocket socket (52) | Creating socket. Using TLS 1.2. | 2018-08-15 05:35:24
BitMEX WebSocket socket (52) | Connecting to IP: 54.194.47.252. | 2018-08-15 05:35:24
BitMEX WebSocket | Opening WebSocket. | 2018-08-15 05:35:24
BitMEX WebSocket | Sending WebSocket handshake. | 2018-08-15 05:35:24
BitMEX WebSocket socket (52) | Socket gracefully closed by remote side. | 2018-08-15 05:35:25
BitMEX WebSocket socket (52) | Received socket Close event. | 2018-08-15 05:35:25
BitMEX WebSocket | Header line. HTTP/1.1 400 Bad Request | 2018-08-15 05:35:25
BitMEX WebSocket | WebSocket not connected. Handshake acknowledgment: HTTP/1.1 400 Bad Request | 2018-08-15 05:35:25
BitMEX Trading Direct | WebSocket closed. | 2018-08-15 05:35:25
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-15 05:35:25
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:35:25
BitMEX WebSocket | Header line. Server: awselb/2.0 | 2018-08-15 05:35:25
BitMEX WebSocket | Header line. Date: Wed, 15 Aug 2018 05:35:24 GMT | 2018-08-15 05:35:25
BitMEX WebSocket | Header line. Content-Type: text/html | 2018-08-15 05:35:25
BitMEX WebSocket | Header line. Content-Length: 138 | 2018-08-15 05:35:25
BitMEX WebSocket | Header line. Connection: close | 2018-08-15 05:35:25
BitMEX WebSocket | Header line. | 2018-08-15 05:35:25
BitMEX WebSocket | Web socket state is now open. | 2018-08-15 05:35:25
BitMEX Trading Direct | Connected to data and trading server. | 2018-08-15 05:35:25
BitMEX WebSocket | Extension reserve bits set and not supported. | 2018-08-15 05:35:25
Connection to the external service has been lost. | 2018-08-15 05:35:25
BitMEX WebSocket socket (52) | Initiating close of socket by core. | 2018-08-15 05:35:25
BitMEX WebSocket | Network socket for WebSocket has been closed by remote side. | 2018-08-15 05:35:25
BitMEX WebSocket socket (52) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-15 05:35:25
BitMEX WebSocket socket (52) | Closed. | 2018-08-15 05:35:25
BitMEX WebSocket socket (0) | Ignored Send call based on current state. | 2018-08-15 05:35:25
BitMEX Trading Direct | Disconnected. | 2018-08-15 05:35:25
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:35:25
Intraday data recording state for symbol XBTUSD-BMEX is set to download 'Pending'. | 2018-08-15 05:35:25
HD Request # 16 | Downloading Intraday chart data for XBTUSD-BMEX to the file XBTUSD-BMEX.scid. Service: bitmex | 2018-08-15 05:35:25
HD Request # 16 | Download start date-time: 2018-08-15 05:35:17.000 | 2018-08-15 05:35:25
HD Request # 16 | Using server: ds4.sierracharts.com port 10149 | 2018-08-15 05:35:25
Socket (53) | Creating socket. | 2018-08-15 05:35:25
Socket (53) | Connecting to IP: 192.81.56.146. | 2018-08-15 05:35:25
HD Request # 16 | Setting DTC encoding to Binary VLS | 2018-08-15 05:35:25
HD Request # 16 | Sending historical data logon request message. | 2018-08-15 05:35:25
HD Request # 16 | Requesting Intraday data. Start date-time: 2018-08-15 05:35:17. Record interval: 1. Symbol: XBTUSD-BMEX | 2018-08-15 05:35:25
HD Request # 16 | Decompressing data. | 2018-08-15 05:35:26
HD Request # 16 | Receiving Intraday data for XBTUSD-BMEX starting at 2018-08-15 05:35:17 | 2018-08-15 05:35:26
HD Request # 16 | Timestamp of first Intraday data file record written: 2018-08-15 05:35:17 | 2018-08-15 05:35:26
Socket (53) | Initiating close of socket by core. | 2018-08-15 05:35:26
Socket (53) | Shutdown started. Waiting for graceful close. | 2018-08-15 05:35:26
HD Request # 16 | Historical data for XBTUSD-BMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-08-15 05:35:26
Historical data download thread signaled to stop. | 2018-08-15 05:35:26
HD Request # 16 | Received 4 records from 2018-08-15 05:35:17 to 2018-08-15 05:35:25 (8.0 seconds) and wrote 4 records for XBTUSD-BMEX | 2018-08-15 05:35:26
HD Request # 16 | Completion time: 0s | 2018-08-15 05:35:26
HD Request # 16 | Intraday data download complete for XBTUSD-BMEX. Unique request ID: 15 | 2018-08-15 05:35:26
Removed historical data download ID 15 | 2018-08-15 05:35:26
Socket (53) | Socket gracefully closed by remote side. | 2018-08-15 05:35:26
Socket (53) | Closed. | 2018-08-15 05:35:26
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-08-15 05:35:28
BitMEX WebSocket | Connecting to WebSocket server. | 2018-08-15 05:35:28
BitMEX WebSocket socket (54) | Creating socket. Using TLS 1.2. | 2018-08-15 05:35:28
BitMEX WebSocket socket (54) | Connecting to IP: 52.51.127.8. | 2018-08-15 05:35:28
BitMEX WebSocket | Opening WebSocket. | 2018-08-15 05:35:28
BitMEX WebSocket | Sending WebSocket handshake. | 2018-08-15 05:35:28
BitMEX WebSocket | Header line. HTTP/1.1 400 Bad Request | 2018-08-15 05:35:29
BitMEX WebSocket socket (54) | Socket gracefully closed by remote side. | 2018-08-15 05:35:29
BitMEX WebSocket socket (54) | Received socket Close event. | 2018-08-15 05:35:29
BitMEX WebSocket | WebSocket not connected. Handshake acknowledgment: HTTP/1.1 400 Bad Request | 2018-08-15 05:35:29
BitMEX Trading Direct | WebSocket closed. | 2018-08-15 05:35:29
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-15 05:35:29
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:35:29
BitMEX WebSocket | Header line. Server: awselb/2.0 | 2018-08-15 05:35:29
BitMEX WebSocket | Header line. Date: Wed, 15 Aug 2018 05:35:28 GMT | 2018-08-15 05:35:29
BitMEX WebSocket | Header line. Content-Type: text/html | 2018-08-15 05:35:29
BitMEX WebSocket | Header line. Content-Length: 138 | 2018-08-15 05:35:29
BitMEX WebSocket | Header line. Connection: close | 2018-08-15 05:35:29
BitMEX WebSocket | Header line. | 2018-08-15 05:35:29
BitMEX WebSocket | Web socket state is now open. | 2018-08-15 05:35:29
BitMEX Trading Direct | Connected to data and trading server. | 2018-08-15 05:35:29
BitMEX WebSocket | Extension reserve bits set and not supported. | 2018-08-15 05:35:29
Connection to the external service has been lost. | 2018-08-15 05:35:29
BitMEX WebSocket socket (54) | Initiating close of socket by core. | 2018-08-15 05:35:29
BitMEX WebSocket | Network socket for WebSocket has been closed by remote side. | 2018-08-15 05:35:29
BitMEX WebSocket socket (54) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-15 05:35:29
BitMEX WebSocket socket (54) | Closed. | 2018-08-15 05:35:29
BitMEX WebSocket socket (0) | Ignored Send call based on current state. | 2018-08-15 05:35:29
BitMEX Trading Direct | Disconnected. | 2018-08-15 05:35:29
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-15 05:35:29
Intraday data recording state for symbol XBTUSD-BMEX is set to download 'Pending'. | 2018-08-15 05:35:29
HD Request # 17 | Downloading Intraday chart data for XBTUSD-BMEX to the file XBTUSD-BMEX.scid. Service: bitmex | 2018-08-15 05:35:29
HD Request # 17 | Download start date-time: 2018-08-15 05:35:25.000 | 2018-08-15 05:35:29
HD Request # 17 | Using server: ds3.sierracharts.com port 10150 | 2018-08-15 05:35:29
Socket (55) | Creating socket. | 2018-08-15 05:35:29
Socket (55) | Connecting to IP: 65.182.172.42. | 2018-08-15 05:35:29
HD Request # 17 | Setting DTC encoding to Binary VLS | 2018-08-15 05:35:30
HD Request # 17 | Sending historical data logon request message. | 2018-08-15 05:35:30
HD Request # 17 | Requesting Intraday data. Start date-time: 2018-08-15 05:35:25. Record interval: 1. Symbol: XBTUSD-BMEX | 2018-08-15 05:35:30
HD Request # 17 | Decompressing data. | 2018-08-15 05:35:30
HD Request # 17 | Receiving Intraday data for XBTUSD-BMEX starting at 2018-08-15 05:35:25 | 2018-08-15 05:35:30
HD Request # 17 | Timestamp of first Intraday data file record written: 2018-08-15 05:35:25 | 2018-08-15 05:35:30
Socket (55) | Initiating close of socket by core. | 2018-08-15 05:35:30
HD Request # 17 | Historical data for XBTUSD-BMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-08-15 05:35:30
Historical data download thread signaled to stop. | 2018-08-15 05:35:30
Socket (55) | Shutdown started. Waiting for graceful close. | 2018-08-15 05:35:30
HD Request # 17 | Received 3 records from 2018-08-15 05:35:25 to 2018-08-15 05:35:29 (4.0 seconds) and wrote 3 records for XBTUSD-BMEX | 2018-08-15 05:35:30
HD Request # 17 | Completion time: 1s | 2018-08-15 05:35:30
HD Request # 17 | Intraday data download complete for XBTUSD-BMEX. Unique request ID: 16 | 2018-08-15 05:35:30
Removed historical data download ID 16 | 2018-08-15 05:35:30
Socket (55) | Socket gracefully closed by remote side. | 2018-08-15 05:35:30
Socket (55) | Closed. | 2018-08-15 05:35:30
File >> Disconnect selected. | 2018-08-15 05:35:31
BitMEX Trading Direct | Disconnected. | 2018-08-15 05:35:31
[2018-08-15 17:07:16]
This is the reason. We think this has something to do with rate limiting on the part of BitMex.
Anyway, one problem we see is you are running an older version of Sierra Chart. You need to update. This is essential. Many updates have been done with the interface to BitMex. You are running an out of date version. Please follow our instructions here on this:
Now that in and of itself is not going to solve the problem, but you do need to be on the current version when using BitMex.
