Date/Time: Tue, 21 Jan 2025 10:42:18 +0000
Access to my previous posts
View Count: 731
[2018-08-15 13:49:07] |
User252419 - Posts: 235 |
I won't use this account for a few time. Will I be able to see my previous posts? How could I keep seeing my previous posts? Thank you |
[2018-08-15 17:09:04] |
If your Support Board posts are public, then you can just bookmark the Thread or Post URLs. And you can always login to your Sierra Chart account, even if it is expired, if you want to view your own posts: https://www.sierrachart.com/SupportBoard.php?do=ViewPosts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-15 17:09:42
