Date/Time: Tue, 21 Jan 2025 07:25:47 +0000
Retain study setting for individual symbols
View Count: 607
[2018-08-15 04:40:54] |
User629461 - Posts: 184 |
Hi, I'm playing with the Zig Zag and Zig Zag Cumulative Volume studies and would like to know how to retain study settings for individual securities and timeframes, as this varies by symbol. When I change to a new symbol on the watchlist, I modify the study settings to suit that symbol, however when I go back to the previous symbol, the study settings are changed. Thanks |
[2018-08-15 05:43:06] |
This is not supported. You just must use completely separate charts for each symbol configured as you require.
