Date/Time: Tue, 21 Jan 2025 07:45:31 +0000
sc.ScrollToDateTime not Resetting
View Count: 718
[2018-08-14 17:00:08]
kas64h - Posts: 87
I've been using sc.ScrollToDateTime to scroll a chart.
I set it using sc.ScrollToDateTime.SetDateTime(NewDate); etc., and the chart scrolls fine.
However, according to the documentation it should then reset itself to zero.
It doesn't appear to be doing the reset, resulting in any user key press etc., scrolling the chart back to the position set by sc.ScrollToDateTime (obviously not desirable).
I've tried clearing it manually using sc.ScrollToDateTime.Clear(), but this results in the chart scrolling to the end.
Can you please take a look.
Thanks.
[2018-08-14 17:35:57]
In the next release, it will be cleared. But if you are clearing it, then it becomes 0 and then it is just ignored. There should not be any problem with this.
Date Time Of Last Edit: 2018-08-14 17:36:23
