Date/Time: Wed, 22 Jan 2025 07:06:05 +0000
Study Request - Polarized Fractal Efficiency
View Count: 1129
[2018-08-14 16:29:55] |
infpz - Posts: 826 |
https://rtmath.net/helpFinAnalysis/html/2feb9112-ab1a-44ff-baf7-231cdf9fefff.htm Formula is in the above link |
[2018-08-14 17:24:41] |
We will look into this. Although not sure how soon we can get to it
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-14 17:24:49
[2018-09-12 20:59:12] |
Looks like this was done - thx.
[2018-09-12 21:41:36] |
John - SC Support - Posts: 37369 |
Yes, this was just added in release 1803. You will find the documentation here: Polarized Fractal Efficiency For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
