Date/Time: Tue, 21 Jan 2025 07:36:19 +0000
Too small to see
View Count: 1687
[2018-08-14 13:58:51]
User753716 - Posts: 1
my GC changed last week: 1. text way too small to read when I click File>Open Chartbook; 2. Price column on right side of charts (all charts) too small to read, useless; 3. toolbar icons extremely small, very difficult to use; all lines in TNT, majors/minors, pressure, now very thin, difficult to use. Is there a reset? I tried to revert to previous GC, no luck.
[2018-08-14 17:07:43]
You must be using a different resolution for the screen than you were before. The first, and easiest, fix would be to simply change the screen resolution back to the setting you had previously.
The other option is to simply change the Graphics Settings for Sierra Chart to make everything readable again. The main items you want to update will be in the Font tab of the Graphics Settings, as you will want to increase the size of the fonts. Refer to the following for how to change the fonts:
Graphics Settings: Fonts and Text Appearance
Once you have these set, you can now save these for later recall. Refer to the following:
Graphics Settings: Saving and Loading Multiple Graphics Settings Configurations
