Date/Time: Tue, 21 Jan 2025 10:51:00 +0000
Large Volume Trade Indicator Text Color
View Count: 944
[2018-08-12 16:08:03] |
TSiSVT - Posts: 21 |
Is there a way to change the text color from white on the Large Volume Trade indicator? If not, can it be implemented?
[2018-08-14 20:31:57] |
John - SC Support - Posts: 37327 |
The text color for the Large Volume Trade Indicator is using the Chart Text color as set in the Graphics Settings. Refer to the following documentation for this item: Graphics Settings: Chart Text We will look into adding an option for the coloring of the text in the study. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-15 18:35:19] |
We have added an option to the Large Volume Trade Indicator Study for the color of the text that is displayed. This will be in the next release - 1789. When available, you can download the release using these instructions: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
