Date/Time: Tue, 21 Jan 2025 07:42:24 +0000
TPO unusable with V 1788
View Count: 677
[2018-08-12 06:21:36] |
Rassitude - Posts: 33 |
Not sure what is happening with 1788 but TPO is unusable, it takes 1mn + when you click on anything on any chart type, particularly TPO.
[2018-08-12 07:00:47] |
We observe no problems with TPO Profile charts on 1788. Most likely the issue is what is documented here: http://www.sierrachart.com/index.php?page=doc/helpdetails30.html#ChartTickSizeAndVolumeAtPriceProcessing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
