Date/Time: Sun, 24 Nov 2024 10:49:30 +0000
sharing data between installed copies of sc
View Count: 1197
[2013-10-21 12:48:49] |
User16114 - Posts: 153 |
I have followed the instructions in "Sharing Data Between Installed..." but stuck at instruction number 5. when using "File >> Find Symbol" in the destination copy (AMP/TTNet)of SC the "Instance:" list box is not allowing me to choose "IQFeed [data]" (data source). The "Instance:" drop down is greyed out and not available. SC "IQFeed [data]" (the Source) and SC "AMP/TTNet [trading]" (destination) are both open and connected with my respective username and passwords. Not sure what I need to do to get this right. |
[2013-10-21 14:44:56] |
This has to do with differences with the administrator level access with the two copies of Sierra Chart you are running: https://www.sierrachart.com/index.php?l=doc/MultipleServices.html#SharingWithAdminAccess Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-10-21 16:56:19] |
thanks, that fixed it!
