Date/Time: Tue, 21 Jan 2025 07:41:57 +0000
working off line
View Count: 1418
[2018-08-12 03:50:59] |
User968625 - Posts: 260 |
Hello, I have SC data I am trying to work with charts offline , or online, without connecting to IB. I understand that I have to connect , at least, once a month but I just did that. I keep getting errors and window with title "service connection error" that says "note: Is the Interactive Broker TWS software running and is enabled for socket clients" Can you let me know how to just be able to work offline and replay chart. planing to travel and taking laptop to just do that Thank you |
[2018-08-12 21:09:56] |
This section here should answer your questions: Sierra Chart - Software Login Instructions: Working Off-Line Without an Internet Connection Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
