Date/Time: Tue, 21 Jan 2025 07:41:02 +0000
Stock Options
View Count: 883
[2018-08-12 01:41:05] |
Joseph Keller - Posts: 19 |
After researching the help pages, I am stuck. I am trying to load a stock option into a chart. The underlying stock symbol is SPY. I am following the format found at http://www.sierrachart.com/index.php?page=doc/IBSymbols.html#Option I loaded the following for the SPY September, 04, 2018 $282 Call option: SPY-OPT-20180904-282-C-SMART-100-USD Sierra Chart says the symbol is not found? |
[2018-08-12 22:27:09] |
It is Trader Workstation saying the symbol is not found. In general that does seem correct to us. You really need to ask Interactive Brokers for further help. Perhaps the strike price is not properly formatted. Maybe you need to use 282.0 For further information, refer to: Interactive Brokers Symbols: Accessing Contract Description in TWS for Symbol Details Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-12 22:27:21
