Date/Time: Tue, 21 Jan 2025 07:33:47 +0000
[Programming Help] - Create my own ACSIL functions
View Count: 1129
[2018-08-11 21:39:13] |
ForgivingComputers.com - Posts: 988 |
I would like to create my own functions similar to the way sc.Functions work. How do I add my own functions to my studies to make my code more modular? Do I need to declare it in the headers section and then define it in the Data Processing section?
Date Time Of Last Edit: 2018-08-11 22:11:50
[2018-08-13 08:44:12] |
Marmany - Posts: 307 |
Bradh, you simply write and call a study function. As illustrated in attached - adapted from published SC study.
SwingHighAndLow.cpp - Attached On 2018-08-13 08:42:51 UTC - Size: 5.48 KB - 489 views |
[2018-08-13 12:42:45] |
Thank you Marmany. I think the part that threw me "_S" as part of the function name, and the "sc" as part of the parameter list. I assume those are required. I will give it a try! BradH |
[2018-08-13 17:06:35] |
Here is the relevant documentation: ACSIL Programming Concepts: Passing ACSIL Interface Members Structure To Secondary Function C++ Functions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
