Date/Time: Tue, 21 Jan 2025 07:39:47 +0000
Spread Order Entry (Monitoring) don't works in Replay mode
View Count: 682
[2018-08-11 17:56:28] |
TedMar - Posts: 190 |
can not find way to enable "Spread monitoring" in replay mode, any idea?
[2018-08-11 20:42:18] |
This is not supported at this time.
