Date/Time: Tue, 21 Jan 2025 07:26:51 +0000
64-Bit sierra
View Count: 1428
[2018-08-11 16:30:14] |
User41288 - Posts: 13 |
Hi, I wanna 64-bit sierra on my 64-bit operating system. But everytime I am getting 32-bit Sierra. Pls tell me how to get around 64-bit.Regards
[2018-08-11 20:43:40] |
You should see a shortcut on your desktop that has _64 at the end. Use that one to start Sierra Chart.
[2018-08-11 21:29:48] |
ForgivingComputers.com - Posts: 988 |
If Infinity Futures is where you get Sierra Chart from, then you can't just do it by running sierrachart_64.exe. There is an FAQ on my website addressing this: https://forgivingcomputers.com/ufaqs/i-have-infinity-futures-and-i-want-to-run-64-bit-sierra-chart/ I have attached the CMD files mentioned in the FAQ. Brad Houser |
sierra_32.cmd - Attached On 2018-08-11 21:27:49 UTC - Size: 87 B - 432 views sierra_64.cmd - Attached On 2018-08-11 21:28:11 UTC - Size: 87 B - 482 views Attachment Deleted. |
