Date/Time: Tue, 21 Jan 2025 07:32:47 +0000
Extend Value Area Lines to the Right Edge
View Count: 1413
[2018-08-11 14:45:43]
RMos22 - Posts: 27
I have a volume profile plotted using the VP Draw Tool on Aug. 4, 2018 with Extend Value Area set to 'End of Window' and Volume Graph Period Type set to 'From Start Date-Time to End Date-Time but I don't see the VA lines extended all the way to the current date. It appears that once the profiles are no longer visible on the current screen, the VA lines are no longer extended to the right. Has anynone found a way around this limitation?
[2018-08-13 17:47:13]
What is the ending date of the volume profile?
[2018-08-13 19:47:53]
RMos22 - Posts: 27
The ending date is also on Aug. 4, about 2.5 hours long profile.
[2018-08-14 21:53:58]
Okay we understand, this is a limitation. The only option you can use is to extend the line until future intersection.
