Date/Time: Tue, 21 Jan 2025 07:44:29 +0000
Issue with Gold intraday chart monthly bars
View Count: 1642
[2018-08-10 17:04:31] |
User353585 - Posts: 66 |
http://www.sierrachart.com/image.php?Image=1533920562801.png This is CQG F.US.GCEZ18 Continuous Contract with 1 Month Bar setting. As you can see in the picture, it randomly prints a number of abnormal bars. I've tried re-downloading the data and different settings with no avail. can I fix this issue? |
CQG Gold Monthly Bar.Cht - Attached On 2018-08-10 17:03:16 UTC - Size: 20.63 KB - 468 views Attachment Deleted. |
[2018-08-10 18:02:46] |
FYI, now I see the same problem with bitfinex cryptocurrency symbols too. So it's not just with gold.
Date Time Of Last Edit: 2018-08-10 18:05:28
[2018-08-10 19:49:59] |
Looks like you are using Intraday chart data in that particular chart you posted an image of. You should use historical Daily chart data instead. To do this, go to that chart and select Chart >> Bar Period >> Monthly.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-10 19:50:12
[2018-08-11 07:11:18] |
No, I'm using intraday charts because I use tick based indicators on them. I just stripped off the indicators before capturing the image. Intraday Daily and Weekly bars are working fine. Please take a look into the issue if you can. thanks. |
[2018-08-11 09:41:52] |
We see the problem. We will have this resolved in a couple of days.
