Date/Time: Tue, 21 Jan 2025 07:25:42 +0000
Chart displaying issue with new release 1787
View Count: 773
[2018-08-10 17:04:16] |
User657944 - Posts: 173 |
I downloaded the new 1787 since it was solving the issue with poc values and extension lines in numbers bar and it works, but it is not usable since 90% of my charts are not visibible i.e. you see pixel chart like in the attached example. I'm using windows 7. Please check thx
graphic issue1787.png / V - Attached On 2018-08-10 17:03:03 UTC - Size: 122.96 KB - 261 views |
[2018-08-10 17:11:50] |
Update I saw another post on support board with same issue so I upgraded to 1788 and all seems fine now
[2018-08-10 17:43:01] |
Sorry Guys but I discovered that the 1788 solved the pixel chart issue but on the right click manu for color only the number of the color are displayed while not the colro and also on Initial Balance indicator I can't show more than the second High tg so I think it as normal for a pre release need some fine tuning I'm coming back to 1785.
[2018-08-13 16:43:21] |
John - SC Support - Posts: 37327 |
but on the right click manu for color only the number of the color are displayed We will look into this.The Initial Balance study is definitely fine. You just need to set the Draw Style for the particular subgraphs you want to display, to a visible style: http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#DrawStyle For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-14 04:11:06
