Date/Time: Tue, 21 Jan 2025 07:34:21 +0000
TWAP not visible on Volume @ Price Indicator
View Count: 1302
[2018-08-10 13:57:37] |
User993067 - Posts: 156 |
When using the trading DOM with Volume at price indicator applied: 1. I cannot get TWAP to become visible..cant find the setting I suppose 2. I cannot figure out how to get the VAH VAL VWAP lines to be in the foreground of the profile ( the VAH and VAL are foreground...but VWAP is always background) 3. Also when increasing size of plot or changing plot of these lines...they intermittently respond...(ie no changes possible) |
[2018-08-10 14:38:51] |
1. What is TWAP? 2. Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image 3. We really need to understand how you are displaying these lines. So seeing the image is important. Also first probably best that you refer to the documentation here: Volume By Price Study: Calculating and Displaying Developing Point of Control, Value Area High/Low, Volume Weighted Average Price Lines Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-10 14:39:34
