Date/Time: Sun, 24 Nov 2024 11:14:32 +0000
report a bug
View Count: 1436
[2013-10-21 09:08:52] |
SKY - Posts: 45 |
on "chart setting" there is a TAB - "Advanced Setting" (the middle one) checkbox next to "Display Main Price Graph ....Windows" well - if u uncheck it - still the data checked in the "Settings" box are still presented my understanding is that in order to present any data item of "Setting" box depends on whether "Display Main Price Graph ....Windows" is checked ... unless I miss something it looks like a simple bug to be fixed |
[2013-10-22 01:44:41] |
Yes, you are correct. When you uncheck that option the other settings within the Settings box are not going to take effect.
[2013-10-22 03:56:11] |
SKY - Posts: 45 |
so .... u r going to fix that bug ... right ? |
