Date/Time: Tue, 21 Jan 2025 07:30:39 +0000
Connecting to Rithmic
View Count: 1244
[2018-08-09 20:45:22] |
User360056 - Posts: 2 |
Hi, I am taking a trial with Oneup at the moment. I have been able to connect the data feed in Seirra Charts and the chart book is updating fine. I have connected the Oneup login with Rithmic, but unable to connect the Seirra Charts with Rithmic. Trades taken within Rithmic are reflected. But trades taken in Seirra do not show on Rithmic or show profit loss in Seirra also Can you help me connect the Seirra charts to Rithmic Trader Dashboard. Thanks and regards |
[2018-08-09 21:57:16] |
You need to disable Trade Simulation Mode: Overview of Trading: Difference between Simulated and Non-Simulated Trading Modes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
