Date/Time: Tue, 21 Jan 2025 07:21:28 +0000
BitMEX Trading Direct error: Access Denied
View Count: 2379
[2018-08-09 20:45:00] |
User411038 - Posts: 1 |
New order rejected - BitMEX Trading Direct error: Access Denied. Internal Order ID: 77. Service Order ID: (none). Symbol: XBTUSD-BMEX | 2018-08-10 00:13:59 *
[2018-08-09 21:58:09] |
Could you contact BitMex about this and provide them your BitMex account number and also the particular API key you are using. The Access Denied error is from BitMex.
