Date/Time: Tue, 21 Jan 2025 07:34:33 +0000
session times question
View Count: 1424
[2018-08-09 20:40:01] |
Glenn Infinity - Posts: 103 |
a customer has an ES chart that has day session times on it but when I change the symbol on the chart to YM or NQ, the day session times do not duplicate. It takes me back to the 23 hour session, and will not allow them to change them to the day session times. is there a setting that I am missing to either duplicate the session time when I change the symbol or allow me to change it manually? charting version 1781 |
[2018-08-09 22:35:31] |
and will not allow them to change them to the day session times. This can only be true in the case where the chart is being referenced by another chart. This is explained here:Chart Session Times: Session Times Automatically Changing Unexpectedly The relevant section of documentation related to this is here: Global Symbol Settings: Setting of Intraday Chart Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-10 12:33:15] |
Thank you!
