Date/Time: Sun, 24 Nov 2024 08:31:12 +0000
Why doesn't the Sell Limit show up on the 2r chart?
View Count: 1119
[2013-10-21 05:42:04] |
reggytrades - Posts: 29 |
I have 2 charts in the Chartbook, one is 2r, the other is 5r. Both are in trade mode. See that the Sell Limit only appears on the 5r chart?
EURJPY 0.020 rng #1 41568.234.png / V - Attached On 2013-10-21 05:41:35 UTC - Size: 80.91 KB - 393 views EURJPY 0.050 rng #2 41568.234.png / V - Attached On 2013-10-21 05:41:51 UTC - Size: 99.77 KB - 376 views |
[2013-10-21 07:14:19] |
Do you have Trade >> Only Orders from Chart enabled on the chart where you do not see that Limit order?
