Date/Time: Tue, 21 Jan 2025 07:32:15 +0000
Something up with NISS data?
View Count: 562
[2018-08-09 14:16:18] |
User11638 - Posts: 21 |
For some reason my NISS chart has not updated since 9:55. I have used "Reload and Recalculate" several times to no avail, and tried shutting down and re-starting. My datafeed is through CQG. Thank you. |
[2018-08-09 14:27:33] |
This has been resolved.
