Date/Time: Tue, 21 Jan 2025 07:46:07 +0000
Bar duration always 0 in TVW/CTV
View Count: 662
[2018-08-09 08:50:53] |
nus1 - Posts: 39 |
Using numbers bars calculated values. Bar duration would deploy on chart properly, but show 0's in TVW/CTV for any candle. Every other study shows fine.
[2018-08-09 22:46:48] |
This will be supported in the next release.
