Date/Time: Tue, 21 Jan 2025 07:35:13 +0000
Drawing objection question
View Count: 1015
[2018-08-09 02:57:04] |
User786248 - Posts: 25 |
Hi Whenever I make a line/ray/horizontal drawing in one of my charts, the drawing object moves automatically to the right margin instead of staying of staying on the point in the chart. Any way to fix this? THanks |
[2018-08-09 20:54:21] |
The drawings should not be moving to the right margin as you are stating. Can you please attach a screenshot showing where you originally placed the drawing and then where it moved to. There are times when drawings appear to move based on variable timeframe chart bars. It does not sound like this is exactly what you are stating, but be sure to review the following documentation to see if this may be what you are experiencing: Lines/Rays or Other Chart Drawings Move After Drawing Them Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-09 20:54:46
[2018-08-09 21:29:59] |
http://www.sierrachart.com/image.php?Image=1533850166732.png
[2018-08-09 22:15:03] |
One of the market depth historical graph indicators might be causing this behavior. In attached chart, I run 2 market depth historical graph. One of them is causing the drawings to move to the right margin.
[2018-08-10 15:33:48] |
John - SC Support - Posts: 37327 |
Can you please supply us with the Chartbook that is showing this problem using the following instructions to attach the chart to this thread: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-13 17:28:01] |
It sounds like you what you really are experiencing is that the chart drawings are under the study graphs. You might want to display those lines above the graphs. Refer to: Chart Drawing Tools: Controlling Display Order of Chart Drawings Relative to Graphs Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-13 17:28:29
