Date/Time: Sun, 24 Nov 2024 10:35:18 +0000
Line Drawing problem
View Count: 1243
[2013-10-20 21:19:05] |
HalGE - Posts: 39 |
Hi folks I finally figered out how to draw a line in one chart and have that same line apear in another chart... Now... the problem... I dont want to do that anymore and I can not find a way to turn that OFF !!!! Please help Thanks Hal |
[2013-10-21 00:52:58] |
Chart >> Chart Settings >> Advanced Settings 2 >> Copy Chart Drawings from Chart Numbers
[2013-10-21 13:09:24] |
HalGE - Posts: 39 |
You posted... Chart >> Chart Settings >> Advanced Settings 2 >> Copy Chart Drawings from Chart Numbers -------------------------------------------------------------------------------- and yes that is how I got the lines drawn in one chart to apear in the other... in my case I drew the line in Chart No 7 and it was also drawn in Chart No 1 Maybe you misunderstood my question.... HOW do I STOP it from doing that? the box that I put the numbers into in this case I think it was 7,1 are NOT in that box so I cant see how to remove what isnt there... Thanks Hal Date Time Of Last Edit: 2013-10-21 13:11:14
[2013-10-21 14:54:17] |
When you have removed the chart numbers from the box, the lines copied over from other charts will be removed from the chart. Any Chart Drawings manually drawn on the chart itself, can be removed with Tools >> Erase All Lines. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
