Date/Time: Tue, 21 Jan 2025 07:41:20 +0000
ParabolicSAR indicator bug
View Count: 685
[2018-08-08 18:23:21] |
TheTallOne - Posts: 1 |
Hello, I've have repeatedly seen an issue with the ParabolicSAR indicator that I cannot explain based on how I know the SAR is calculated. In the attached image, you will see where the SAR appears to revert to a slower acceleration factor/slope before returning to the previous AF/slope. Based on a standard SAR calculation, there should be no reason for a SAR's acceleration factor to be reduced. Is this a bug? Please advise. Thank you |
IMG_8390.jpg / V - Attached On 2018-08-08 18:21:08 UTC - Size: 80.31 KB - 298 views Attachment Deleted. |
[2018-08-08 18:29:17] |
We are certain that is coded into the study to avoid the result from touching the bar even if it is just an adjacent bar. The source code for this study is available. Refer to: How to Build an Advanced Custom Study from Source Code: Searching for Source Code for Sierra Chart Built-In Studies We remember this was something probably requested years ago. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-08 18:29:47
