Date/Time: Tue, 21 Jan 2025 07:40:12 +0000
can this update constantly or are they predicated on bar completion?
View Count: 692
[2018-08-08 16:47:51]
Glenn Infinity - Posts: 103
I need to know if it is possible for indicators on a higher time frame (which I've set up on a scanner) to update their values in real time, not the time of the higher time frame?
. I’ve set the Scanners so that a “color background” gives me a conformation. These give me a signal in real time. It would be helpful if I could get the higher time frame indicator values to update constantly, which would give me a heads up that the background color is about to change.
[2018-08-08 17:59:34]
This is certainly the case now. Studies do update in real time. Tell us the name of one of the particular studies which apparently is not updating in real time.
[2018-08-08 18:43:54]
The scanner chart is scanning ADX in 4 different time-frames. “Color Background” changes when alerts are met. ADX, +DI, –DI & ADXR values on the scanner chart do not update until that time frame is complete. I would like to have those values change on the scanner as they change in the current time.
[2018-08-09 05:15:50]
ADX, +DI, –DI & ADXR will update at every chart update. But if you are running a scan, you will want to make sure this option is enabled:
General Settings Window: Subscribe RT Data and Download Historical Data During Scan (Global Settings >> General Settings >> General >> Data)
Date Time Of Last Edit: 2018-08-09 05:16:09
