Date/Time: Tue, 21 Jan 2025 07:41:26 +0000
Reject chart trade orders that WON'T immediately fill?
View Count: 883
[2018-08-08 15:28:57] |
User284663 - Posts: 44 |
I'm looking to reduce slippage by using marketable limit orders at the specified price, if the bid/ask changes as I click/or while the order is travelling to exchange - I would like to automatically cancel the pending limit order. Thank you Edit: Also what's the deal with the "Buy ask" and "Sell bid" buttons, wouldn't that just do what a market order does? Date Time Of Last Edit: 2018-08-08 15:39:48
[2018-08-08 18:24:22] |
You might try to use the Time in Force of Immediate or Cancel: Basic Trading and the Trade Window: Main >> TimeInForce (Time in Force): Although this may not be supported by the exchange. Edit: Also what's the deal with the "Buy ask" and "Sell bid" buttons, wouldn't that just do what a market order does? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-09 18:26:52] |
So you're saying that if I simply use the "buy ask" and "sell bid" buttons, I will not have to worry about setting time in force to immediate or cancel? I tried setting the time in force to immediate or cancel however my limit orders still came up pending. Edit: It's showing "Child client" type pending limit orders. Date Time Of Last Edit: 2018-08-09 19:29:10
[2018-08-09 20:56:53] |
Not really. You may still want to try that particular Time in Force. A Child Client order would be for an Attached Order. Are you referring to Attached Orders? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-10 01:05:06] |
Yes, I am using an attached order, a bracket order. 2 tick target/stop. When I have TIF set to immediate or cancel the non marketable limit orders are still pending and aren't cancelled if not immediately filled, i.e. the child client order line displays, I am not familiar with "child client" in general. How should I proceed? |
[2018-08-10 01:40:22] |
There simply is no support for what you are looking when using Attached Orders.
